Radion Antenna options
Old Jul 19, 2010 | 11:59 PM
Jonk67's Avatar
Jonk67
How modern is your radio? I considered the electric one but think I'm going to put the am/fm hidden ant. in the trunk, they use them on boats, etc. as I don't listen to FM much anymore. I plan to install a satellite radio ant. in place of the telescopic one for a cleaner look and that's what I listen to mostly. No worries of it catching on anything and my radio is set up for it. I'll probably pic one up at the JY off a newer mustang, here's a pic of the one on my wife's '09 that would go with the '67 body lines I think unless I spot a better looking one (more low profile).
Jon
Old Jul 20, 2010 | 05:46 AM
2+2GT's Avatar
2+2GT
Originally Posted by tx65coupe
I have seen cars that had any of the three things happen. The antenna was bent or broken, or the fender was slightly deformed from something happeneing to the antenna. Most of the time they are just broken, and I don't want to have to mess with it.
In 35 years of driving my 66, I have broken the antenna twice, once when run off the road by a truck, and once when I got stupid with a car cover. No 'bending' of the fender occurred either time. Oh, and that's a total of 400,000 miles. I wouldn't consider that something to worry about 'messing' with.
If two incidents in over three decades is too much trouble, use an electric retractable.
Old Jul 20, 2010 | 11:45 AM
leroman's Avatar
leroman
I think i will go with this one :
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Jul 20, 2010 | 12:32 PM
Jonk67's Avatar
Jonk67
Looks like a nice unit, does your radio have a power feed to make it go up/down as the radio/ignition goes on/off or will you need to install a manual switch?
Jon
Old Jul 20, 2010 | 01:36 PM
kalli's Avatar
kalli
i like the idea of different angle setups, but you sure that will fit under the fender? never checked in there. ignore. just saw they're selling for mustangs
Old Jul 20, 2010 | 06:58 PM
64.5stanger's Avatar
64.5stanger
I am planning to weld the hole up and install a amplifyed ant. under the fender.
Old Jul 20, 2010 | 07:30 PM
2+2GT's Avatar
2+2GT
I'd check the reception quality on that before doing any welding.
Old Jul 20, 2010 | 07:33 PM
noroof66's Avatar
noroof66
When I installed years ago, those amplified ones never worked well. They would amplify static and not really filter.
Jon has a good idea, if you are just going with satellite radio you have tons of options.
I have a solid mast that twists off at the bottom, so for a car cover etc. I just twist it off. I also like the ones that push all the way in the fender.
Old Jul 22, 2010 | 06:13 AM
tx65coupe's Avatar
tx65coupe
My biggest issue is the breaking of the antenna not the fender damage. When I got the car it was broken and shortly after putting a new one on it magically was broken one day after school. They are flimsy and easily broken. I just didn't want to worry about that. I'll stick with the stainless whip antenna. Its simple.
Old Jul 22, 2010 | 11:37 AM
rst08tierney's Avatar
rst08tierney
Originally Posted by leroman
remember this unit needs to be mounted to the inside of your quarter (for a coupe) and is a PITA to install. Since you have a fastback this should be a non-event.
