rally pac
Old Aug 4, 2010 | 06:25 AM
tx65coupe's Avatar
tx65coupe
I think being color keyed looks better. It looks sweet either way though.
I'll probably just keep watching Ebay for the earlier style for a good deal.
Old Aug 4, 2010 | 07:26 AM
kalli's Avatar
kalli
jgstang65:
i have original rpm gauge and it does not work since I use ignition boxes. I once got expensive module that will cause to pull energy from ignition wire to key (through rpkm gauge), but I think i blew it. Sick of it and going to put after market gauges into it as well.
I can see you use sport comps. can I ask what size and what modifications (apart from cabling) you had to do to pack them in there?
Old Aug 5, 2010 | 01:20 AM
tx65coupe's Avatar
tx65coupe
Does anyone know if I can use a reproduction rally pac with a Pertronix distributor?
Old Aug 5, 2010 | 06:42 AM
kalli's Avatar
kalli
pertronix and no box: yes you can. not a problem. I did that originally without the box.
the way the rally pacs work is that they are in series with the coil+ and ignition key. no matter if you use points or pertronix, the spark created causes the voltage on coil+ to change slightly. The rally pac picks up on this.
if you use an ignition box with it (like me, or MSD or anything else), then the setup changes in such a way that _nothing_ is connected to coil+ or coil- apart from the box. The box gets the impulses and handles the coil. Usually the coil+ will then run at 400V (not 12V). if you'd hook up anything using 12V there you end up with toast
Hope that makes it clear. I ran the pertronix II billet distributor without added ignition box (just like you do) and aftermarket rallypac (from sacramento-mustang) no problem. and the same should be valid for the original rally pac since it works the same way.
A "normal" post 1980 (parallel) style will pick it up from coil- (on/off) or from tach trigger in box. the rally pac (series style tach) is waaay different
ohh and before you ask: the manual (wiring) talks about the resistor wire (can't remember if it suggested with or without). For me it worked with and without resistor wire
Old Aug 5, 2010 | 09:09 PM
plainsman1876's Avatar
plainsman1876
Awesome looking car
Old Aug 6, 2010 | 08:17 PM
tx65coupe's Avatar
tx65coupe
Thanks for the detailed reply. That is a great explanation. I had no idea that the box generated 400V.
Old Aug 7, 2010 | 04:41 AM
kalli's Avatar
kalli
tx65coupe: higher voltage on the primary will cause higher output on the secondary (spark). That's one of the ideas of an ignition box.
plainsman1876: if you mean my car that's an honour. I never expected one to comment on my car where everyone has one :-) thanks :-)
squishbang
Dec 4, 2015 02:29 PM
Sep 25, 2015 09:06 AM
Ford_Dude
Sep 15, 2015 03:25 PM
kdryan
Aug 21, 2015 04:01 PM
65GTin GA
Nov 13, 2005 08:00 AM
