Caster/Camber '66 alignment question
Old Aug 27, 2010 | 05:51 PM
67mustang302's Avatar
67mustang302
Originally Posted by Opentracker
We often put washers under the front bolt on the 67-70 cars to add some caster so you don't have to pull as much on the lower arm. It help keep the tire away from the front of the fender. We do it on the early cars too if they have a camber kit and adj. strut rods.
That's what I did on my 67.
Old Aug 27, 2010 | 06:32 PM
001mustang's Avatar
001mustang
My alignment shop adjusted camber first.
The toe was out so much the shop claimed they had to redo the camber once toe was set.
If my shop is correct then it may be good to get toe fairly close first?
Old Aug 27, 2010 | 11:04 PM
67mustang302
Toe always gets set LAST. Always. Adjusting caster and camber change toe.
Old Aug 28, 2010 | 03:59 AM
nba1341's Avatar
nba1341
Set toe last I mean I doubt your tires are so toed in or out that they need to be set first (as in they squeal when you barley even roll forward)
And always remember to roll the car forward and back on the flat surface after making adjustments. That way your measurements will be accurate and you won't be like wtf I just adjusted the tie rod in so much and the tire didnt move
Old Aug 28, 2010 | 07:34 AM
W Mahoney's Avatar
W Mahoney
Thanks to all. BTW after trying the fastrax tool I highly recommend it . Price for both
caster/camber and toe gauge from Summit is around $200. MM
Old Aug 28, 2010 | 11:50 PM
001mustang's Avatar
001mustang
I've heard of putting a couple greased flat cookie sheets under tires to allow wheels to move while adjusting alignment.
I am considering making slip plates using loose ball bearings and 1/4" steel plates. Would be nice if I could do my own alignment. Wonder how accurate is the fastrax?
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
