1965 Mustang Conversion questions
Old Sep 9, 2010 | 09:47 PM
Dweed777's Avatar
Dweed777
Default 1965 Mustang Conversion questions
I have a 65' that had a 289 V8 setup. Then someone made it into a 6cylnder setup. I am setting it up again for a V8.
I just took off the fron drum brakes and converting them to disc. What else needs to be done on the front? I have a new suspension kit that is going to be put in aswell. I am not going to do that till I know what to purchase and change in the front.
So what else needs to be changed in the front? I know the Spindels need to go back to V8.
Old Sep 9, 2010 | 09:57 PM
JMD's Avatar
JMD
Does the car 4 lugs or 5 lugs?
Hmmm, maybe your 65 was used as a swap parts car?
If you have to change EVERYTHING, there is a good parts list or two in the FAQ section.
Old Sep 9, 2010 | 10:14 PM
Dweed777's Avatar
Dweed777
It was 4 lug when I bought it. It is 5 lug now.
Old Sep 10, 2010 | 12:29 AM
andrewmp6's Avatar
andrewmp6
Read this http://www.mustangandfords.com/howto...ade/index.html
Old Sep 13, 2010 | 04:00 PM
Dweed777's Avatar
Dweed777
Would I be able to use the same Rear end that I bought to put into a 67? Also would I need a different suspension kit then the one I put in the 65'?
Old Sep 13, 2010 | 04:03 PM
2+2GT's Avatar
2+2GT
The 65-66 suspension was the same.
67-70 has a wider rear axle than 65-66.
Old Sep 13, 2010 | 11:48 PM
Dweed777's Avatar
Dweed777
I also was thinking about converting it to PowerSteering. It will be a summer driver. I will be doing both city driving and highway driving with it. PS is more for City where MS is more for Highway?
I am not sure which would be better for my situation.
Old Sep 13, 2010 | 11:58 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Manual steering is more responsive and less vague feeling...i can turn the wheel sitting still in my 65 with 8 inch winder tires using just a couple of fingers...id prefer to not have the engine bay clutered up and no leaks fro ps under the car
Old Sep 17, 2010 | 03:15 PM
Dweed777's Avatar
Dweed777
I am having the engine rebuilt. What should I use Headers or Exhuast manifold?
Diode Dynamics
28
May 26, 2022 12:02 PM
ding56
Aug 14, 2015 02:40 AM
StangMuscle
Aug 12, 2015 07:27 AM
$A_Money$81
Aug 11, 2015 01:30 PM
daytooday
Aug 11, 2015 09:22 AM
