1965 Washer pump
Old Oct 19, 2010 | 07:49 PM
tx65stang's Avatar
tx65stang
Default 1965 Washer pump
On my 65 I have the 2 speed wipers with a 2 speed switch, and am looking to replace the washer pump. I noticed when comparing my existing unit to what's in the MU catalog, it appears I have the pump with the single speed wipers. I'm assuming these aren't interchangeable correct?
Old Oct 20, 2010 | 05:42 PM
tjmat's Avatar
tjmat
no they are not interchangeable. most 65 mustangs had a one speed so there's a very good chance that's what you have
Old Oct 20, 2010 | 06:40 PM
uibalnme's Avatar
uibalnme
Well, the pump only needs +12V and ground. Find the wire coming from the switch that's supposed to run the pump, and connect the pump to that. If you're in the market for a new pump anyway, NPD has a washer pump for a 66 with 2-speed wipers.
National Parts Depot catalog number: 17664-2A $42.50
Old Oct 20, 2010 | 06:45 PM
CarGuyZM10's Avatar
CarGuyZM10
Most, but not all. I know they were part of the visibility group, along with adjustable driver side mirror, and a day night mirror.
As for the other question, did you try other places like Virginia Mustang or C. J. Pony?
Old Oct 20, 2010 | 09:26 PM
tx65stang's Avatar
tx65stang
I can't say with any certainty, but I think the car came with the visibility group. It has the adjustable side mirror and day/night mirror. Its' whether or not some PO added these features at a later date.
I have not checked with any other suppliers as of yet.
Also the 2 speed pump I've seen pictured in several places has 2 wires emanating from it. I assume one was connected to the switch and the other to a ground, possible attached to the mounting screws. Correct?
Old Oct 21, 2010 | 07:28 AM
2+2GT's Avatar
2+2GT
It doesn't matter on a 65. The same pump was used either way. If MU says otherwise, they really need to correct their listings. Glazier/Nolan has the pumps listed correctly, and they stock the pump you need.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
Bokeo
Oct 10, 2015 08:28 PM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
mrappe
Sep 26, 2015 10:16 AM
