late model 65 build.
Old Oct 31, 2010 | 06:06 AM
tx65coupe's Avatar
tx65coupe
Originally Posted by broncomitch,
ya, im not to happy about it. but it's just for around town use. when it's time to take it to the track ill buy some better one's....tho if i can get 300 for em that will be a good start.
a few of my friends use spacer's on there rig's 1 jeep on 37's a 4runner on 38's and a sami on 40's no problem's and there used on the street all the time.
been told to re tourqe em once a month.
got some more work done today.
rebuilt the shifter,got my ing switch put togauther (dont ask me how cus i have no idea) wired up the nuetral safty and backup switch. (tested and was still good) seems like im having to replace anything electronic lol
i could't find the emer flasher switch but found my old one off my 72 f250 back from hight school that is the same switch! got that wired up and mounted in the glovebox.
how can i tell if my heater is a 2 or 3 or 4 speed? i think it's a two, off-on-high? ill try and post some pic
Does your heater box have a connector on the front? It sounds like its a 2 speed. Mine is a 3 speed and has 4 positions and has a connector on the front of the heater box with a large connector and a single terminal.
Old Oct 31, 2010 | 09:32 AM
JamesW's Avatar
JamesW
The other problem I had was that on another set, after about 2 months, they developed hairline fractures in the aluminum. I removed them, concerned that they would break and separate.
Old Oct 31, 2010 | 01:49 PM
tcrote5516's Avatar
tcrote5516
I had a set work the studs loose and begin to pull through the aluminum. These are just plain BAD BAD BAD all around.
Your talking about the a location with the highest level of force/stress in a vehicle coming from all directions at all times X 4 possible failure locations = 99.9% probablity of catastrophic failure at some point*
*Math and probability calculations sourced from by a** but are probibly not that far off.
Old Oct 31, 2010 | 06:31 PM
broncomitch,'s Avatar
broncomitch,
what wheel's are those?
you guy's suck. your talking me out of it
guess ill hold off on them for now and look around for some wheel's.
Old Oct 31, 2010 | 06:34 PM
broncomitch,
it has 3 prong's on top and the switch plug's right into it the there is 1 male end and i think another one but it broke in half.
Old Oct 31, 2010 | 06:38 PM
broncomitch,
i was thinkin of getting these or some like it....but dont like the full chrome look and painting chrome cost to much $$$. kong make's one's like it for 105 each....but i dunno.
Old Oct 31, 2010 | 08:07 PM
hightower2011's Avatar
hightower2011
Please don't do that to a mustang....
Old Oct 31, 2010 | 08:44 PM
JamesW's Avatar
JamesW
http://www.midnightdsigns.com/AJ/Adapter/DSC00119.JPG
http://www.midnightdsigns.com/AJ/Adapter/DSC00125.JPG
First link shows how the studs had worked themselves loose in the spacer. they fell out by hand. The second shows how the how the loose stud allowed the lug nut to wear the hole.
Old Nov 1, 2010 | 12:39 AM
andrewmp6's Avatar
andrewmp6
At a local scca event i seen a car the spacer sheered the lugs straight off and did some damage when the wheel went flying off.If you get the rims cheap enough a wheel smith can fix the back spacing but its not cheap to have done.
Old Nov 1, 2010 | 06:00 AM
tx65coupe's Avatar
tx65coupe
Sorry but those wheels are hideous. That also looks like it came from the Foose shop.
