Crankshaft issue
Old Dec 13, 2010 | 06:59 PM
chrisbazzard's Avatar
chrisbazzard
Default Crankshaft issue
Ok here is my problem i have a 67 mustang and im replacing my old 302 in it with a new one i brought i paid $200 for a 302 bored .40 over with forged everything but when i came to assemble it i found that the crank bearings are standed and the crank is undersized but i dont know how to find out how undersized it is to find out how big of bearings i need if any one knows what a standed crank size is i will use a micromiter on mine and figure out how much undersized it is.?
thank you
chris
Old Dec 13, 2010 | 07:25 PM
2+2GT's Avatar
2+2GT
You could always use Plastigage on it.
Old Dec 13, 2010 | 07:44 PM
chrisbazzard
so do the caps up with the standed bearings and undersized crank then take the caps back off and read the pastigage and get bearings that much biger?
Old Dec 13, 2010 | 09:58 PM
2+2GT's Avatar
2+2GT
That's about it. Except I think you mean smaller.
Old Dec 13, 2010 | 10:06 PM
JMD's Avatar
JMD
Rod Journal Diameter (in) 2.123 in.
Main Journal Diameter (in) 2.248 in.
The mains I am sure of , I need to check the rods out further, can't find my interchange book...
Old Dec 14, 2010 | 08:43 AM
kalli's Avatar
kalli
I had to think about that for a while. bearing shell wider, but resulting inner diameter smaller?
Old Dec 14, 2010 | 10:08 AM
chrisbazzard
yeah ok i just tryed the plastigage idea and the gap is way biger then plastigage. so im in the proses of removing the crank then i will do the cap back up with out the crank in there and measure the size of the standed bearing then measure the crank then minus the two numbers and that's how much bigger my bearings need to be right?
Old Dec 14, 2010 | 11:44 AM
cprstreetmachines's Avatar
cprstreetmachines
Just have a machine shop measure it to make sure you get the right bearings.
Old Dec 14, 2010 | 12:42 PM
chrisbazzard
i just did it myself the bearings are 2.2499 and the crank is 2.2300 so a .020 diff so i need .020 bigger bearings..
Old Dec 14, 2010 | 12:44 PM
chrisbazzard
that sounds right i just measured mine and they were 2.249in
thanks man
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
