Suspension
Old Dec 14, 2010 | 08:12 PM
Joes65's Avatar
Joes65
Default Suspension
Evening all, I am looking at the next project for my 65 coupe to be the suspension and I need some opinions. My overall plan is to replace the rear leafs and shackles with the 5 leaf kit with the 1" drop from CJ's. I was also planning to replace the front upper and lowers with oem style and using a 1" shorter spring. Does this sound reasonable? Do I need to do both at the same time?
Thanks for any help or advice.
Old Dec 14, 2010 | 08:29 PM
Gun Jam's Avatar
Gun Jam
Yeah that sounds fine it should tighten things up a bit if the LCA and UCA are worn.
I would do the front first so it doesn't drive around squatting.
Old Dec 14, 2010 | 08:58 PM
mikenkiki05's Avatar
mikenkiki05
do what gunjam is telling you im getting alot of feedback on my 65 mustang coupe from him and quite a few others, this forum has helped me alot, i have been told on the lowers to lower the car down before you tighten the lower control arm bolt that bolts a arm to frame bracket so it dont twist the bushing, if your going to the extent like i am im replacing everything suspension wise shocks, springs, leafs spring perches i mean everything, just like you are the only thing im not replacing (i hope) is the front springs but while i have everything out i may just spend the money and get them and sell my old ones for like 20-30 bucks each+ shipping, nothing is wrong with them at all im just doing it for a peice of mind issue is all i bought the car for my wife and i want it to be perfect! :0 )
Old Dec 14, 2010 | 09:32 PM
Joes65's Avatar
Joes65
Thanks Gun.
Pretty much what I'm doing Mike. I figured I would get the coil springs while I had everything apart.
Old Dec 15, 2010 | 08:26 AM
Starfury's Avatar
Starfury
1) I would reconsider the 5 leaf rears. They're going to be very stiff. I have 4.5 leaf mid-eye springs and I'm pretty happy with them. They're very firm (firmer than many would like) without being jarring, and they handle corners great.
2) Get some roller perches and do the Shelby drop while you have the front end apart. You'll appreciate it.
Old Dec 15, 2010 | 08:46 AM
2+2GT's Avatar
2+2GT
This'll help with #2:
Arning/Shelby Suspension Drop
baddog671
Jul 26, 2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
