1973 351C cam question
Old Dec 19, 2010 | 07:55 PM
bailer01's Avatar
bailer01
Default 1973 351C cam question
I am looking to do a cam upgrade on my 1971 351 2V Cleveland. What would you recommend without upgrading the heads, etc.? I am alos looking to get a 4 barrel on it this winter. Right now it is pretty stock but want to wake it up a little.
Thanks
Old Dec 19, 2010 | 08:28 PM
2+2GT's Avatar
2+2GT
I'd use the hydraulic CobraJet cam.
Old Dec 19, 2010 | 08:43 PM
jimkaray's Avatar
jimkaray
Cam makers will provide a summary of the intended use for each model and the basic set they work best with. You to pick a cam that complements your overall set up. I like CompCams for one. I'm assuming you are pretty much stock so check out the 268H to start. If you have a stick &/and a little more gear in the rear then the Magnum 270H is worth a look. Complement that with a dual plane aluminum intake topped with a 600 cfm carb w/ vacuum secondaries. Edelbrock Performer 2V or Weiand has a dual plane that shows 351M but is not referencing the Clevand? They also have a single plane that has a broad power range. Could be good option if you plan to keep performance modding. On my 73 I was happy with my 2V dual plane intake with 600cfm carb, full exhaust, 350 gears, mild head work and high stall converter. Mid to low 14's in the 1/4. its been off the road for too many years now.
Old Dec 20, 2010 | 01:48 PM
CyprusMustang's Avatar
CyprusMustang
jimk, what hp where u hitting?
Old Dec 20, 2010 | 01:49 PM
CyprusMustang
bailer, i got myself same engine as a spare and will tear it up and rebuild it so ill let you know how it works out
Old Dec 20, 2010 | 02:22 PM
kalli's Avatar
kalli
cyprus: first time i see your car. looks sweet. with that weather you have to take a picture with the roof down :-) and quarter window down. I hate pictuires of mustangs with roof down and quarter windows up. looks to me like someone carries two glassblade fins around
Old Dec 20, 2010 | 02:27 PM
CyprusMustang
thanks man, ill post a few soon. its still conv weather. were gonna be like the auzzies this year for xmas if this weather keeps up!
Old Dec 20, 2010 | 02:41 PM
jimkaray's Avatar
jimkaray
Not sure, I estimated it around 350. As you know the '73 is quite the boat
My sportsroof w/ foldown rear seat is approx 3,800 with driver. Torque is your friend to get these babys off the line, don't be to concerened with HP. Also, I was running street slicks.
Old Dec 20, 2010 | 02:44 PM
CyprusMustang
I want my rear end to be all over the place. I mean with my stock 302 its very torqy, i cant imagine how it would be with the built up 351. I wont do too much to it, just want lots of TORQUE!
Old Dec 20, 2010 | 05:55 PM
jimkaray's Avatar
jimkaray
Consider adding a high stall torque converter to that C4 that matches your power band. That way when you stomp on the gas the engine will jump right into the power band, no waiting on the rpm's to build up. Or you could install a nitrous system but be sure the trans is up to it.
Luke9222
Oct 22, 2015 11:55 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
