Front Wheel cylinders leaking?
Old Dec 27, 2010 | 11:10 AM
blazerdup's Avatar
blazerdup
Unhappy Front Wheel cylinders leaking?
I replaced the complete brake system, lines, hoses, wheel cylinders and it appears that the front wheel cylinders are leaking. I have a soft pedal of course too. When I put on the new front brake hoses I used the old washer from the old hose. The new hoses didn't come with the washer so I am wondering if I should have even used them. I can't get them to stop leaking and I am completely frutstrated with it.
Any advice?
Old Dec 27, 2010 | 11:21 AM
mustangted's Avatar
mustangted
leaking at the hoses?
Old Dec 27, 2010 | 11:24 AM
2+2GT's Avatar
2+2GT
Get new cylinders, new hoses, and new copper washers. Cheap enough, and you'll be done.
Old Dec 27, 2010 | 11:34 AM
blazerdup's Avatar
blazerdup
I did all of that except for the new copper washers. It appears to be leaking ever so slightly where the hose connects to the wheel cylinder. The hoses are extremely difficult to tightghen because it's so close to the arm but I believe to have it tight without stripping the damn thing out. I shouldn't have to put any type of sealant on it right because the washer should do the job?
Old Dec 27, 2010 | 12:19 PM
2+2GT's Avatar
2+2GT
OK, but used copper washers have already been compressed and hardened. You can solve this problem for $2.
Old Dec 27, 2010 | 12:29 PM
rtintwo's Avatar
rtintwo
You can buy new washers from your local parts store for a couple of bucks.
Old Dec 27, 2010 | 01:43 PM
blazerdup's Avatar
blazerdup
It looks like I stripped the threads on the hose going into the WC when I originally put it on. I pulled it apart to put a new washer on it and there it was. Am I *** out now and have to buy a new hose and wheel cylinder?
Old Dec 27, 2010 | 03:10 PM
2+2GT's Avatar
2+2GT
I would. My #1 rule is not to eff around with brakes.
Old Dec 27, 2010 | 09:39 PM
blazerdup's Avatar
blazerdup
oh mine too. I am just pissed I messed it up and didn't even know it.... I hope it works when I get the new ones on.
drfister
May 3, 2018 10:38 PM
KinneyD
Jan 9, 2016 05:33 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
cbird1177711
Sep 2, 2015 08:51 PM
