undercoating quarterpanels
Old Jan 12, 2011 | 04:20 AM
gooser's Avatar
gooser
Default undercoating quarterpanels
does anyone undercoat quarterpanels? i mean all the way up.
Old Jan 12, 2011 | 06:55 AM
NoReins's Avatar
NoReins
Sure you can. Several car builders spray the entire interior structure with Lizard Skin or similar products to assist with heat and sound deadening. It's not going to hurt.
Old Jan 12, 2011 | 12:06 PM
mr_velocity's Avatar
mr_velocity
Coated the entire inside with POR15, put it on so it would run out all the seams. Places that need sound deadening got Lizard skin, the rest got body wax.
Old Jan 12, 2011 | 08:07 PM
001mustang's Avatar
001mustang
I just use epoxy primer and weld through primer.
Epoxy I put inside front fenders has held up for about 15 years so far.
I occasionally drive in the rain but never in the snow or wet salted roads.
I try to run seam sealer in way that does not trap water and debris.
Old Jan 12, 2011 | 08:18 PM
mr_velocity
+1 on the seam sealer. I also used an epoxy seam sealer.
Old Jan 12, 2011 | 08:38 PM
BuckeyeDemon's Avatar
BuckeyeDemon
are you looking for rust protection or sound deadening?
Old Jan 12, 2011 | 08:52 PM
tx65coupe's Avatar
tx65coupe
I don't like any of the under coating etc. I feel that it has the potential to hold in moisture if there is a chip or nick in it or if some of it comes off.
I would rather use something like POR 15 or something from Eastwood and then paint it.
Old Jan 12, 2011 | 09:30 PM
gooser's Avatar
gooser
sound deadening buckeye. you've all been very helpful on this one. also gave me the answer i wanted to hear.
guitarman376
Oct 11, 2015 01:47 AM
green_blurr
Jan 27, 2007 03:38 AM
Bulldog66
Dec 7, 2006 11:22 PM
69Mach_1
Sep 18, 2006 03:03 AM
Andrew7
Jun 26, 2006 11:20 AM
