Has anyone put their carpet in the dryer?
Old Jan 16, 2011 | 08:44 PM
  #21
scootchu's Avatar
scootchu
Originally Posted by JMD
Hmmm... if there was only some kind of HEAT you could turn on in the car....
I had the heater on for a bit, but it's like a drop in the ocean. Today was warmer. I had a reading of 55 in the sun on my back porch. I put down the top and let the sun beat down. I have a few lumps on the from pans. I was going to put a case of water on each side and let them sit for a while.
Old Jan 17, 2011 | 01:42 AM
  #22
tx65coupe's Avatar
tx65coupe
It looks like it went in pretty nicely. I noticed the washers too. LOL...
Old Jan 17, 2011 | 10:38 AM
  #23
zmetalmilitia's Avatar
zmetalmilitia
Originally Posted by scootchu
Uggggghhhhhhhhhhhhhh I knew someone would say something. I will replace them mommmmmmmmmm.
Haha. Sorry! I couldn't resist.
Old Jan 17, 2011 | 11:40 AM
  #24
JMD's Avatar
JMD
Sorry, I had to say it... anyway, maybe a pan of HOT tap water sat down on the lumps....
Old Jan 17, 2011 | 01:09 PM
  #25
FoMoJoe's Avatar
FoMoJoe
Maybe loosen up the bolt, slide some paper under the washer, mask the carpet, and hit with a black rattle can?
Old Jan 17, 2011 | 01:17 PM
  #26
scootchu's Avatar
scootchu
Ahhh the bolts were only in there to keep the carpet in place. I am going to replace them with some fender washers of some sort. Easy to remove.
Old Jan 17, 2011 | 01:55 PM
  #27
scootchu's Avatar
scootchu
Okay back from the hardware store with 4 new fender washers, lock washers and bolts. Pics to come when it's above 32 degrees. LOL
Old Jan 18, 2011 | 09:51 AM
  #28
Novice-Owner-Marc's Avatar
Novice-Owner-Marc
Sounds like you and I are in the same boat...... Can't work because of the temp in the garage...
I had to put my 67 coupe on hold because it is about zero in my garage on most days. I bought the "garage door insulation" and a portable heater, now I just need to get the heater cranking for some time before I put up the insulation.
Ok, enough ranting on my part.... Let's see those pictures when you get them.
1996cobraconvertible
SVT Forums
13
Jan 7, 2016 04:50 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
9550
Oct 26, 2015 05:01 PM
Sminemann
Sep 17, 2015 09:24 AM
LivingInThePast
Sep 16, 2015 12:20 PM
