Issue with my dipstick
Old Jan 30, 2011 | 07:54 AM
musnicki's Avatar
musnicki
Originally Posted by Recon111
What ever dip stick you use, change your oil and filter. add 5 qts of oil, start the engine, shut off, check oil level. Mark oil level somehow on your dipstick. That would be Your full mark.
Duh...good tip. I have a 351 double sump oil pan, so 5qts..but also need to add one more quart for the filter right?
Old Jan 30, 2011 | 08:48 AM
JMD's Avatar
JMD
It seems as if some (all) of the aftermarket timing covers have the dipstick hole too small for most aftermarket dipsticks, the last couple I had were anyway.
Of course this is something one usually doesn't think about till the last moment....
On Jim's I just bit my lip and drilled the dipstick boss on the fully assembled engine bigger, this was after destroying the stock tube and starting to destroy a replacement. No way it was going in.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
