Quick choke spec question
Old Feb 2, 2011 | 10:14 AM
MustangFTW
Guest
Posts: n/a
Default Quick choke spec question
What size drill bit do I need to calibrate my autolite 2100.
I'm pretty sure I need 2 different sizes, one for adjusting before pushing piston in and one after.
Old Feb 3, 2011 | 09:48 AM
MustangFTW
Guest
Posts: n/a
where can i apply vacuum to see how the choke reacts? which opening is it on a 2100?
Old Feb 6, 2011 | 06:39 AM
kalli's Avatar
kalli
you want to have it in such a way that when closed the choke plate is nearly closed and when warm fully open. and when accellerating cold the choke plate opens to allow more air in (this is done with the piston in the choke housing).
The shop manual has exact procedure and drillbit size. other than that you only need a bent paperclip. However I find the instructions quite unclear so I used those. after using them I understood what they were trying to say in the shop manual
http://www.hurtle.com/cars/mustang/fixes/carb/
I'll check in that shop manual later
kalli
Old Feb 6, 2011 | 08:32 AM
MustangFTW
Guest
Posts: n/a
Thanks but I found it, it was 1/8
carb rulotslot better now.
Old Feb 6, 2011 | 12:31 PM
kalli's Avatar
kalli
ya, they are great carburetors. It was the easiest one I ever had
Old Feb 6, 2011 | 12:37 PM
MustangFTW
Guest
Posts: n/a
runs alot* stupid iphone.
but ya i love this carb.
tmdm
May 2, 2021 02:49 PM
Big Al's 03
Sep 15, 2015 09:05 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
Mustangmalo
Sep 6, 2015 05:22 PM
