URGENT HELP NEEDED
Old Feb 6, 2011 | 05:29 PM
001mustang's Avatar
001mustang
i agree.
give it a good look see.
if nothing i would pull starter and check it out.
I've dumped a mustang in my youth
Old Feb 6, 2011 | 05:41 PM
65mustang65's Avatar
65mustang65
worst case scenario and it isnt the starter, what should i be looking for?
Old Feb 6, 2011 | 08:43 PM
001mustang's Avatar
001mustang
busted bell.
so pan is not bent?
auto trans?
Old Feb 6, 2011 | 09:49 PM
MustangFTW
Guest
Posts: n/a
worst case scenario huh?
your car explodes next time you start it.....
on a serious note.
if the car didnt hit the ramps when it fell where did it get damaged, shouldnt the suspension take that? you said that you pulled the ramps out by hand afterward right?
Old Feb 6, 2011 | 09:59 PM
65mustang65
yes, the ramps were kind of wedged a bit under the front fenders right behind the wheel, so nothing hit them on the way down. i think that something got jarred loose when it hit the ground and is rubbing.
Old Feb 6, 2011 | 11:55 PM
eZ's Avatar
eZ
Wait does it start? Could be something as simple as a wire coming loose from the impact...like a wire coming off the ballast resistor?
Old Feb 7, 2011 | 08:59 AM
65mustang65
Default update
The car is an automatic. starter turns and car cranks then horrible noise after cranking. Oil pan is straight. sounds like it is coming out of the transmission. I put my hand on the starter and had my son turn it over. Hard to tell where noise is coming from. Afriad is in the transmission. never saw anything like this. I will pul the starter and see.
Old Feb 7, 2011 | 10:36 AM
kalli's Avatar
kalli
re-read 2+2's post. I think he's on to something
Old Feb 7, 2011 | 12:12 PM
65mustang65
Default thought about tranny
I would have though the same thing , but the car was in drive and driven over the end of the ramps. Was a big bump but nothing humongous. I am afraid the impact point being right behind the wheels is so close to the meeting point of the engine and transmission. The car landed right on that line for just a split second. I do not want to remove the transmission and it was just rebuilt Ijust praythat when I take out the starter it is the culprit. Bendix is fully engaged or something readily apparent. I will have it tested anyway. Thanks for these ideas.
Old Feb 7, 2011 | 12:40 PM
001mustang's Avatar
001mustang
... wonder how those duke boys get away w/ all that car flying...lol
mustang can't even fly off the nest?....
say it aint so.........
