289
Old Feb 8, 2011 | 11:00 PM
1967coupeon101's Avatar
1967coupeon101
Default 289
does this sound right? how hard is it to tune an engine?
http://www.youtube.com/watch?v=80vbwXZwKhQ
Old Feb 9, 2011 | 05:45 AM
2+2GT's Avatar
2+2GT
Is that engine hot or cold? Does the choke work?
Not a fan of Holleys. Your idle isn't working, of course, sometimes the bowl gaskets shift and no idle results.
Old Feb 9, 2011 | 08:04 AM
MustangFTW
Guest
Posts: n/a
doesnt sound right to me...sounds rough.
Old Feb 9, 2011 | 11:02 AM
frdnut's Avatar
frdnut
Could be many things..Cold engine with no choke(althought it appears that it is on?),vacuum leak,idle mixture needs to be richened up,ignition timing off....Also check the plug wires to make sure you have them in the correct order and that they are all on tight and making connection..
Old Feb 9, 2011 | 11:22 AM
001mustang's Avatar
001mustang
agree.
get engine hot before fine tuning.
tune idle to produce off white plugs.
verify good engine to frame ground.
can hot wire coil to remove variables.
adjust all in total timing to match build; 32-36 is common.
can run full time or ported vac to distributor; depending on goal.
can pop condenser plate to verify centrifugal stops function and spec.
can recurve distibutor if feeling saucy.
uberstang1
Dec 7, 2017 07:10 AM
GTJIM
Sep 23, 2015 09:59 AM
ryland
Sep 13, 2015 12:35 PM
Brian Emmer
Sep 9, 2015 02:50 PM
ding56
Aug 14, 2015 02:40 AM
