timing question, ect
Old Mar 12, 2011 | 10:11 PM
mikenkiki05's Avatar
mikenkiki05
Default timing question, ect
what is a factory setting for timing we have ours at 7 degrees advanced without vacum lined connected and 25 total advance with vac advance hooked up is this a safe timing setting or no
289 4 barrel 600 cfm eldebrock carb with a eldebrock matching intake
we have hooker headers with 2 inch pipes with glass packs electronic ignition (pertonixII)
and what should idle be set at also
we have ours set at 725 when its cold and it goes to 757 when motor warms up
what should lifters be set at also we have one that is rattling on right bank but before i touch any of them i want to see what they should be set at i beleive its a hydrolic cam as i didnt build the motor 2 owners before us build it and have no clue how to get ahold of him
Old Mar 13, 2011 | 07:48 AM
hotrod351's Avatar
hotrod351
depends on the year for the timing. 6 to 10, as long as it doesnt ping. lifters, if adjustable hyd, anywhere from 1/8th to 1 turn from clicking. sometimes you can get a lazy lifter that will click for a while then stop.
Old Mar 13, 2011 | 08:08 AM
2+2GT's Avatar
2+2GT
I advance the timing until a slight ping can be detected, when accelerating at WOT. Then back off 2°. This gives you the best power and mileage. No number can be carved in stone, because each engine is slightly different. My 289HP runs very well at 14° BTDC initial timing.
Old Mar 23, 2011 | 04:23 PM
.boB's Avatar
.boB
On a new stock engine, use the book recommendations. But, on a real engine that's been modded or has a lot of wear, the stock settings are only a guideline.
Set base timing where the vacuume level is the highest at the proper idle rpm.
Or, if you don't have a vacuum gauge, get a glass of water and set it on the fender. Turn the distributer until the ripples in the water are the smoothest.
Max mechanical advance should put you at about 34* at 3,000 rpm's. Vacuum advance should provide 6-10* of advance at cruise.
Most SBF's loose power with more than about 34* of total advance, so there's not much point in going higher. Unless you test it on the dyno and see what you get.
GimpyHSHS
Aug 29, 2015 06:30 PM
Faolan65
Aug 27, 2015 06:40 AM
Faolan65
Arizona Regional Chapter
Aug 25, 2015 09:24 AM
stormesixx
Aug 25, 2015 09:11 AM
ding56
Aug 14, 2015 02:40 AM
