Inner Rocker Panels.....
Old Mar 26, 2011 | 01:21 PM
CyprusMustang's Avatar
CyprusMustang
Default Inner Rocker Panels.....
Here is day one of changing my inner rocker panels without fuking up the paint of the car. I know i will nick the car here and there but will try and do my best to not have to respray the whole car.
First step is to clean the floorpans so that i can see where the connections are. I will change both floorpans driver and passenger side. I also will change the torque boxes as well.
heres me busting my *** cleaning that crap.
Here you see a couple holes in the rear seat panels. Will try and clean up as much as I can so that I can fix everything once and for all.
Old Mar 26, 2011 | 01:26 PM
CyprusMustang
Here is my plan...
1. clean floorpans to see what actually is going on.
2. install sub frame connectors to strengthen car before i cut it up.
3. remove doors and install braces in between both doors.
4. remove front quarter panels to have access to troque boxes.
5. cut out the old floorpans, driver and passenger
6. cut out torque box with inner rocker panels (good luck to me on this one)
7. install new inner rocker panels.
8. install new floor pans
9. put everything back together
10. take care to paint shop to touch up whatever i fuked up.
Old Mar 26, 2011 | 02:23 PM
2+2GT's Avatar
2+2GT
OK, with one proviso; Do them one side at a time, and do the worst side first.
Old Mar 26, 2011 | 03:20 PM
CyprusMustang
yea agree on that one, makes sense. fukin rocker panels..
Old Mar 26, 2011 | 04:13 PM
jgemperline's Avatar
jgemperline
Cool I'm doing mine too. It's a slow prosses for me. Only get a few hours here and there. I am taking small sections out at a time. I have worked my way to the rear frame rail. This is a tight spot does anyone have tips on this section?
Good luck.
Old Mar 26, 2011 | 04:14 PM
scootchu's Avatar
scootchu
I am going to watch this one. I know what you are up against when you try to do things without undoing others. Good luck you have a fine looking car.
Old Mar 26, 2011 | 10:36 PM
groho's Avatar
groho
It took me an entire day to drill out all the spot welds to separate the inner and outer rocker on a patch I'm doing. Talk about a b#ttload of spot welds. Good luck...bit of advise, purchase extra bits, and extra beer.
Old Apr 1, 2011 | 04:13 PM
CyprusMustang
took my air gun to the dirvers side today and took off the dirvers side pan. tomorrow the rear and then the rocker....
gotta love air chisels
Sixer4Life
Oct 12, 2015 04:26 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
uedlose
Sep 30, 2015 08:01 AM
Sixer4Life
Sep 28, 2015 07:05 AM
JDWalton
Sep 24, 2015 08:47 PM
