2BBL to 4BBL Need help!
Old Mar 29, 2011 | 04:44 PM
Cmwry's Avatar
Cmwry
Default 2BBL to 4BBL Need help!
Hey guys, so I had a original 2bbl carburetor and intake. I am putting on a 289 edlebrock performer 4bbl intake and a holley 600cfm. But I noticed the old carburetor had a PCV valve spacer underneath the actual carburetor. My new intake will not fit that. Does this PCV Valve just connect else where? I'm a little lost and any help is greatly appreciated!
Thanks guys!
Old Mar 29, 2011 | 04:52 PM
frdnut's Avatar
frdnut
It depends on the exact carb you are using but most have a large vaccum port on the rear side that you can hook it up to
Old Mar 29, 2011 | 07:55 PM
emttrevor's Avatar
emttrevor
Default pcv valve
you can either place the pcv at the rear centre port on the new carb as I did or you can place it on the intake at the rear there is an opening that you can place a fitting that you can buy from oreillys or whereever that will screw into the intake and run the hose there if you want. Ive done both and either one will work
Old Mar 29, 2011 | 09:53 PM
Cmwry's Avatar
Cmwry
Ahh ha! I found it guys. It turns out it was on the carb this whole time and I just didn't see it. I appreciate the help guys!
Old Apr 2, 2011 | 04:10 PM
Cmwry's Avatar
Cmwry
Okay guys so I have this holley 1850. I was just wondering if this port needs to be plugged.
Old Apr 2, 2011 | 11:32 PM
frdnut's Avatar
frdnut
Is that going into your choke housing?..It may just be a spot where you are supposed to hook up a heat source to help turn off the choke..As long as its not a vacuum leak while its running it shouldn't need to be plugged..
Old Apr 3, 2011 | 03:11 AM
kalli's Avatar
kalli
yep. that's for the choke tube. it's just a metal tube that goes down to your manifold so hot air gets into the choke to heat it, so it would switch off at some stage. if you have headers you can just wrap a metal tube around the header. you can use the electric choke.
the tube to it's bottom left is for PCV, so connect PCV there. horrible vacuum leak if you leave it open. if you just plug it and don't use PCV your breather on the other side will smoke and oil
Old Apr 3, 2011 | 11:59 PM
Cmwry's Avatar
Cmwry
But it's an electric choke.
Old Apr 4, 2011 | 05:26 AM
kalli's Avatar
kalli
looks like you can use both, heatriser or electric. whatever you prefer. at least that's what it looks like to me. I wouldn't block it, as otherwise it might interfer with the choke pull off piston. not sure about that, but i'm quite sure this should not be blocked.
Kalli
uberstang1
Sep 20, 2015 06:42 PM
ding56
Aug 14, 2015 02:40 AM
70 Mach
Apr 19, 2005 04:52 AM
66_stang
Jul 8, 2004 01:01 PM
kevs66coupe
Feb 19, 2004 04:09 PM
