electronic Speed"O"
Old 04-02-2011, 10:35 PM
mortman
mortman's Avatar
Default electronic Speed"O"
I picked up a full set of Auto Meter "Sport Comp" Gauges. I have an OEM 289 dropped in a used T-5 from a 86 - 89 (dont remember). Using the original sender from the T5, hooked up the speed "o" but cant calibrate. Had my wife follow me in her Hy-bred. After hitting the designated 2 miles and setting the speed"o" back to normal i showed doing 60, she never got over 35 and i never got out of 3rd. Speed "O" jumped when shifting gears.
If i order the correct sender form Auto Meter will this help?. I am thinking the sender from the T5 is dot sending the right PPM's.
Any help would be great.
mortman is offline
Old 04-03-2011, 01:59 AM
mortman
mortman's Avatar
Actually after checking the Auto meter web site the speed sensor "Should" work fine. Odometer seems fine. Original gear was a 16T so i left it in.
Any Ideas as to what the problem is?
mortman is offline
Old 04-03-2011, 07:38 AM
ozarks06
ozarks06's Avatar
I'd make sure you did the calibration correctly. I had to read the instructions a couple of times to make sure I got it right. I had a friend who had a similar problem on his car and it was a bad ground. Since you said the speed jumped when you shifted gears, I'd check that.
ozarks06 is offline
Old 04-03-2011, 09:12 AM
JMD
JMD's Avatar
I think maybe the hybrid might be producing some EMP's causing your difficulties...
Ok, really, I would start with your wiring, making sure all of your connections and grounds are tip top, other than that try it again, and again and maybe you will find success.
I know I have seen some stock spedo wires that are "twisted pair", I am sure to eliminate "cross contamination" from other nearby wires, if all else fails, you might try twisting your sender to gauge wires together along their entire length.
I have usually had good luck with electric speedos hooked to stock senders, not so much luck with the "add on" senders, so I would try to make the stock sender work for a reasonable time before switching out.
JMD is offline
Old 04-03-2011, 11:40 AM
mortman
mortman's Avatar
going to double check the ground and wiring then give another shot.
Jmd, thanks for the tip on the senders, right now i have some cheap mechanical in, so i will try and reuse the stock senders first.
one more question, where can i find the small light sockets for the blinkers that are not self grounding. I have have a temporary ground in them now, works fine except when the headlights are on.
mortman is offline
Old 04-03-2011, 02:12 PM
mortman
mortman's Avatar
Ok you where right bad ground from the speed "O" sensor.
JMD, the original oil and water sensors just peg out, once the motor cools i will swap them with the Auto Meter sensors. then trace down the fuel gauge problem, woks good with a jumper to the sender just mot in the harness.
mortman is offline
mrtrodonet
09-19-2020 03:12 PM
drfister
05-03-2018 10:38 PM
piotrek53
10-13-2015 06:54 PM
yourmom6990
09-14-2015 10:52 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: electronic Speed"O"
