t5 shaft input question
Old Apr 9, 2011 | 11:04 AM
05gtgreen's Avatar
05gtgreen
Default t5 shaft input question
Hi, just wondering what the input shaft length is on the t5 from a 5l mustang. is the input shaft shorter or longer on a 5l t5 compared to a 4 banger t5. thanks
Old Apr 9, 2011 | 08:49 PM
1slow67's Avatar
1slow67
ROTM Moderator
I think they are the same, just the 4cyl isn't rated to withstand as much horsepower.
Old Apr 10, 2011 | 02:42 PM
scott_m_mil's Avatar
scott_m_mil
I was to the understanding that the 2.3L 4 banger t5's had a smaller diameter input shaft with say 20 something splines. The 5.0 has a larger diameter input shaft with 10 splines.
Scott
Old Apr 11, 2011 | 12:55 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Here is a link to a T5 ID chart. It apears that the 4 banger trans has a longer shaft and is smaller where it goes into the pilot bearing. Hope it helps. http://www.fordmuscle.com/archives/2...p/index2.shtml
Old Apr 11, 2011 | 07:05 PM
05gtgreen's Avatar
05gtgreen
I found a t5 from a 94 mustang 5L. Can I just change the input shaft to make it work with my 87 bellhousing and clutch fork. Will this work. Thanks.
Old Apr 11, 2011 | 08:20 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
you can but youd be better off selling it and just buying a 87-93 tranny....or keeping it and buying a 94-95 bellhousing and the shifter will be easier to reach and centered properly in the hole in the floor...
Old Apr 11, 2011 | 09:05 PM
05gtgreen's Avatar
05gtgreen
We already put it in the car like that, seems to line up fine. I am just worried because there was no play in the input shaft (back and forth). Just wondering if there should be play in there?
Tivo304
Aug 28, 2023 12:19 PM
dudeguy421
Sep 24, 2015 11:16 AM
04stangman
Sep 17, 2015 01:45 PM
EASTIDEE123
Sep 15, 2015 11:08 AM
