Glad to help. The passenger side of the engine at the back of the enigine is where the ground wire should be. The head is the top part of the engine that all the valves and the vavle cover are on.
Looking back that was a dumb question. I see no wire there so hopefully that is all the problem is. So the two grounds that are there are insufficient?
Does the cable have to be connected to the passenger head or can I connect it where the ground wire is in the rear passenger bottom side of the engine where there is a bolt already?
I don't understand what the difference of a ground from the block to the solenoid on the engine wall is then a ground from the block to the firewall is. Can you explain that as well?
Yes you should connect it at the back of the head. This is a link with a pic to a ground cable like the one you are looking for. You should be able to find everthing you need at a local parts store, this will be quicker and cheaper.
