73 mustang body help??
Old May 18, 2011 | 11:25 PM
hightower2011's Avatar
hightower2011
Originally Posted by Shawn1532
All right, the tail light panel I can handle, for the quarter panel do I just, cut out a section and try and seamlessly weld the new one in?
The car's got a V6 in it right now, with a 3 speed manual, but I found a 429 cobra jet with a 9" rear end that I want to put in it, think it'll work?
You're going to need to upgrade your transmission and driveshaft. And if your car is 4 lug you'll need to put 5 lug suspension up front.
Originally Posted by rmodel65
why are you mad?
That stupid b*tch ruined my Fridays.
I just hate that song so much. I'd rather listen to white noise and stare at the sun.
Old May 19, 2011 | 12:08 AM
andrewmp6's Avatar
andrewmp6
Its a inline 6 not a v6 and 71-73 there was no 4 lugs they all are 5 lug cars.
Old May 19, 2011 | 09:48 AM
hightower2011
Wasn't sure about that, good to hear it though. Next time I start a project and consider a V6/I6 to V8 swap, maybe I should look at a big '71-'73.
Old May 20, 2011 | 12:40 AM
andrewmp6's Avatar
andrewmp6
Where you think my spindles came from lol.Only reason i knew that was my dad had a 71 sport roof was a inline6 and 5 lug back in the 80s.In 71 they changed a lot like wider engine bay they lowered the upper a arm and went to a gm style steering box.
Old May 20, 2011 | 04:58 PM
jspagna1's Avatar
jspagna1
That's the nice thing about the 71-73 Mustangs, plenty of roonm for a Big Block. As for the rearend it depends on what it came out of as it's also the widest Mustang built.
Anything from a 351 and up and that car will haul ***. My sister had a 73 coupe with a 351 and that thing could light up the tires something fierce.
Old May 20, 2011 | 05:19 PM
jimkaray's Avatar
jimkaray
Add to the swap list motor mounts, accelerator cable, radiator, fan shroud (an electric fan cheaper option), front springs, sway-bars and exhaust headers. Check into the possibility of a brake proportioning valve to go with the 9" rear and trans mount, I believe you may need those as well.
Old Aug 19, 2011 | 03:18 PM
Fordication's Avatar
Fordication
Just curious, was this car given to you?
djbigskrilla
Sep 20, 2022 01:04 AM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
stanngg
Aug 12, 2015 03:43 PM
daytooday
Aug 11, 2015 09:22 AM
