C4 tranny fluid question
Old May 25, 2011 | 12:54 PM
nassaubayman's Avatar
nassaubayman
Originally Posted by rmodel65
it doesnt......
Really? Are you sure? That's not the answer I got a year ago when I asked that question..
https://mustangforums.com/forum/clas...questions.html
My AOD has been in my '67 and running for 10 months now with Type-F fluid in it. No issues (yet).
Old May 25, 2011 | 02:28 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
well if its working for you id stick with it...........
Old May 25, 2011 | 02:42 PM
TexasAxMan's Avatar
TexasAxMan
I use to run type F in GM turbo 350's in which I'd put a shift kit (Shift Improver Kit). It was recommended in the B&M instructions to either use type F or their pricey Trick Shift brand.
Old May 25, 2011 | 02:58 PM
nassaubayman
Yeah, I think rmodel65 failed my pop quiz.
Old May 26, 2011 | 09:24 PM
noroof66's Avatar
noroof66
I do not have AOD, but I did a quick search on the subject and the overwhelming consensus seems to not use type F. Before you damage something, I would double check to be sure.
Old May 26, 2011 | 09:33 PM
nassaubayman
I have probably 2000 miles on it. I'd think I'd be having troubles by now. But it was something I never was too sure about. When I posted my question (a year ago), only one person answered. He seemed to know what he was talking about (but we know how that can get us into trouble). Plus, other posters stating they use Type F in hopped up Chevys makes me more confident.
Old May 26, 2011 | 09:59 PM
mr_velocity's Avatar
mr_velocity
Bauman seems to know a lot about transmissions, in their literature is states "Regarding AOD-E/4R70W Transmissions ...you should never use Type F fluid...as this will damage the converter clutch and other transmission components. Do not be concerned about the inability to use Type F fluid in your transmission, as Type F is actually an inferior fluid whose antiquated formulation is suitable only for use in farm machinery."
The question really comes down to how much difference is the aod vs the 4R70W, when it comes to the clutches I don't believe their is a difference. Personally I'd dump the F and change it to Mercon/Dextron III. 2000 miles is nothing, would you be happy if it smoked at 4000?
Old May 27, 2011 | 03:38 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the 4r70w is an electronic version of the AOD like the AODE but with a slightly wider gear set...Type F doesnt got in an AOD,AODE, or 4R70W
Old May 27, 2011 | 09:28 PM
nassaubayman
Sounds like I might be stopping by a few transmission shops to ask questions. Inquiring minds want to know...
Old May 27, 2011 | 11:31 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
i always run what the factory calls for.........
LivingInThePast
Sep 16, 2015 12:20 PM
prophotog
Sep 15, 2015 08:38 AM
jaiidutch
Sep 14, 2015 10:29 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
