brake pedal not returning
I have a 67 289 convertible. During the restoration I upgraded from drums to power discs on the front (SSBC conversion). Now, the brake pedal does not return to the original position. Should there be a return spring? What causes the pedal to return after you release it?
When I did the dual bowl conversion on my wife's 66, I had to change out the rod due to it being a different length. If you still have the old parts, you might want to look at the length differences and maybe get an adjustable one like TexasAxMan suggested.
It's not just that the pedal does not return to the same position, but the brakes also lock up. I have to pull the pedal back out after braking or the car will not move when in gear. Would the pushrod length affect this?
Sep 25, 2015 06:42 PM
Ghost_Conscience
Sep 23, 2015 02:17 PM
ccdguy
Sep 19, 2015 05:20 PM
Sep 8, 2015 11:50 AM
