Window will not roll up... help
Old Jul 14, 2011 | 09:02 PM
JMD's Avatar
JMD
I think they made regulator repair kits to re-bush the drive gear....
yep,,,, I think I might have found it....
http://www.parts123.com/parts123/yb....~~~~0000024X~F
(edit) Read it again.... maybe not....
Old Jul 14, 2011 | 09:13 PM
Element155's Avatar
Element155
wrong about the salvage yard comment, depending on local climate stuff can be almost pristine
Old Jul 14, 2011 | 10:03 PM
Gun Jam's Avatar
Gun Jam
i got a new "best" one from NPD if it sucks and say the gear breaks in a year I can use the bushings to fix the old one
Old Jul 17, 2011 | 06:31 PM
68GT 302's Avatar
68GT 302
Did you happen to take any pics of this as you were going through it? My drivers side window is really starting to bind up and I am thinking I will have to go in there soon and I am not really sure where to start.
Old Jul 17, 2011 | 08:32 PM
scootchu's Avatar
scootchu
I don't know what your salvage yards look like, but I haven't seen a 60's Mustang lying around for quite some time.
Old Jul 17, 2011 | 08:42 PM
Gun Jam's Avatar
Gun Jam
68GT
its easy it looks super hard initially but alls you gotta do is: (for1966 anyhow)
1) Remove all the handles and pop the door trim off
2) Remove the 4 bolts from the regulator
1) remove the 1 keeper from the regulator arm to scissor
2) hold the window up
1) pop the regulator arm out of the scissor and slide the whole thing out the far access hole
So easy it only takes one step as numbered above!!
-Gun
Old Jul 18, 2011 | 04:58 PM
Gun Jam's Avatar
Gun Jam
Got the new regulator installed. It is a Scott Drake item and it appeared to be built as well or better than the original. It fit nearly perfectly one screw hole had to be slightly enlarged nothing unacceptable. Works smooth but not as smooth as the passenger side (I blame the scissor i bet its worn out as well.)
-Gun
Old Jul 18, 2011 | 05:02 PM
68GT 302's Avatar
68GT 302
Good to hear. Thanks for the tips as well.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
flash_xx
Oct 16, 2015 07:23 AM
Explosive
Oct 2, 2015 07:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
