FAST EZ-EFi system
Old Aug 22, 2011 | 01:31 PM
  #41
Iskwezm's Avatar
Iskwezm
why do you have a boost referenced regulator?
Old Aug 22, 2011 | 01:40 PM
  #42
Norm Peterson's Avatar
Norm Peterson
If you don't reference the fuel pressure to manifold boost, it'll run lean as the boost comes up. Manifold pressure still represents a resistance to fuel discharge, and if you could somehow achieve the silly case where boost = regulated fuel line pressure, you wouldn't get any fuel out at all.
If the car isn't FI yet, there may be plans to do so.
Norm
Old Aug 22, 2011 | 07:10 PM
  #43
ic237's Avatar
ic237
I gotta tell you I absolutly love your car!
Old Aug 22, 2011 | 10:30 PM
  #44
Iskwezm's Avatar
Iskwezm
Norm
thanks norm for a answer i already knew.
I was asking becasue there is no reason to have a boost referenced regulator with no forced induction, unless i missed a hidden blower or turbo
  #45
Iskwezm's Avatar
Iskwezm
Thanks!
Old Aug 23, 2011 | 06:26 AM
  #46
rsusmark's Avatar
rsusmark
Hi Guys...the discussion about reference is correct....sort of in this instance. It's true that if you don't reference the BOOSTED manifold pressure, your fuel could be shut down but that is not why FAST put this on. (my car does not have a blower) The regulator you see on my car is the fuel pressure regulator and they reference the maniforld pressure so that the pressure to the injectors remains proportionate to not only the manifold pressure but atmospheric as well. Basically they are making sure that the A/F ratio does not change do to external changes. These injectors have the capability to feed a much large engine so they want to keep the fuel flow "in the box" by making sure the pressure delivered to the four injectors in the throttle body are the same, no matter what the loose nut behind the wheel does with the throttle or where he points the nose of the car...Pikes peak or the Mariana Trench. BTW, you guys can download the ENTIRE installation manual for this set up from FAST...makes interesting reading before you buy! Reid
Old Aug 23, 2011 | 01:10 PM
  #47
Iskwezm's Avatar
Iskwezm
Thanks, i wasnt want aware of that.I went with a different brand, but still might put on on my boat that is a N/A 514 BB
Old Aug 23, 2011 | 01:58 PM
  #48
ozarks06's Avatar
ozarks06
As far as I know, return-style regulators normally reference manifold vacuum or boost. For boost, it raises the pressure to overcome the boost (39 psi + 10# boost requires 49 psi for the same fuel flow). For vacuum, it reduces the pressure to correct for that. Without correcting for vacuum, the injectors would spray too much fuel since the injector flow is calibrated for a given pressure drop (not absolute pressure at the injector). To set the base pressure, you check with the engine off since it will drop with vacuum (mine is set for 39 psi but at idle it's about 28 psi).
Old Aug 24, 2011 | 10:35 PM
  #49
67 evil eleanor's Avatar
67 evil eleanor
Norm
Very good explanation. Norm is correct as usual.
bradleyb
Nov 27, 2015 07:50 PM
Bokeo
Oct 10, 2015 08:28 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
