overheating problem,
Old Aug 15, 2011 | 03:16 PM
broncomitch,'s Avatar
broncomitch,
Exclamation overheating problem,
when i first started driving the mustang the temp gauge never left the middle of the gauge,now it's getting hot all the time.
this morning i pulled into work with steam comming out of the grill, so when i got off i filled the rad and it was a gallon low, for the most part it stayed cool but when i was about home the temp shot up.
im about to sell this car and i dont want to put alot of money in it, any ideas on what it could be? i keep finding little clumps of what looks like corrosion in the rad, is there anything i can put in there to brake that stuff up???
the guy is picking this car up on saturday!!!
Old Aug 15, 2011 | 03:28 PM
Jackaroo's Avatar
Jackaroo
Probably the lowest cost ways that MAY solve the problem are getting a new thermostat, buying radiator flush, flushing out the goop and refilling with new coolant.
Old Aug 15, 2011 | 04:00 PM
Tilley's Avatar
Tilley
1. check water pump to make sure it is doing its job correctly.
2. you can get a new radiator with a lifetime warranty for about $125.00 (I just got one at AutoZone).
3. fill it with 50/50 Prestone Antifreeze AND distilled water.
4. buy a new thermostat, preferably a 195 degree one. Check it before installing (if you're not sure how, ask and I can refer you to website...super-easy to do).
5. put in new radiator hoses.
You can do this for less than $200 and not have anymore problems. If you have a 289 or larger,you may want to consider a 4-row aluminum radiator with a shroud...BUT ONLY IF 1-5 DOESN'T WORK.
Old Aug 15, 2011 | 04:49 PM
broncomitch,
well, i checked the stat and it opens around 195 even tho it's a 180 and it closed at 180.
the pump seems to be working, i rev the motor up and the water go's down
and water seems to be flowing through the rad with no problems.
and yes im using 100% water, mainly cus it's overheating so much and it's bad for the environment to just be waisting it.
it is a 289 without a shroud but i do have a electric fan and a flex-light fan ( both pulling) thing is, it seems to get hotter with the fan on then turn it off and the temp go's down but then right back up. ( yes im 100% sure there pulling the same way)
I called napa and a rad is $140 something and a pump is $25.
thing is im hurting for money and im already taking a big loss on the car and i really dont want to make it worse.
Old Aug 15, 2011 | 05:36 PM
ic237's Avatar
ic237
Try running the engine at idle with the radiator cap off. If you see bubbles that will not stop coming, then you may have blown a head gasket. Those clumps of rust you see may just be oil in the coolant. see video below
http://www.youtube.com/watch?v=7UyhjT7nWY0
Old Aug 15, 2011 | 07:44 PM
broncomitch,
no bubbles or anything in water, i dont loose any oil and check the coolant level eveyday, no sine of oil.
well i flushed everything out, filled the rad up with fresh water checked for leaks and took it for a spin to cash my check % miles away in stop and go traffic total time was about 25 mins,
stayed in the operating temp range with the fan on and when i got home the water temp was 180-190.
mungodrums
Sep 29, 2015 09:18 PM
stangin1996gt
Sep 21, 2015 11:01 AM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
