How to paint engine?
Old Aug 17, 2011 | 12:43 AM
Mindys67's Avatar
Mindys67
Default How to paint engine?
Painting my '67 289. Should everything (block, intake, heads, water pump, oil pan, dipstick tube) be painted as an assembly, or individually then assembled? Valve covers painted separate?
Pulleys, brackets, balancer semi-gloss black?
Thanks
Old Aug 17, 2011 | 12:53 AM
andrewmp6's Avatar
andrewmp6
i would have it assembled and mask off stuff that don't need paint like the part of the intake opening the carb sits on.Just make sure everything is clean and you use the high temp engine paint.
Old Aug 17, 2011 | 01:10 AM
Canary94GT's Avatar
Canary94GT
I'd say mainly just the block, head and intake need to be assembled for painting, unless you mask off internals/gasket surfaces (the internals you'll need to mask off either way).
I used duplicolor high temp engine paint and it has held up well.
Old Aug 17, 2011 | 10:07 AM
MustangFTW
Guest
Posts: n/a
im doing it now on my 67 289, i painted exhaust manifolds, heads, intake manifold, block, timing cover, oil pan, dark ford blue, and i used a engine high temp primer before that. i painted all the accessories semi gloss black. i could post pics if you want
Old Aug 17, 2011 | 10:46 AM
KMatch's Avatar
KMatch
If it's all one color, paint as an assembly. That's the way it came from the factory. The problem with assembling afterwards is marks on the bolts and around the bolts. It looks assembled and not like an assembly. The exception is for parts of a different color. The best way then is in pieces as it's hard to mask without it looking like it were masked.
Nick Oliver
Oct 17, 2018 04:22 AM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
mustangchef
Sep 4, 2015 08:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
