Granada Conversion for Disk Brakes
Old Sep 19, 2011 | 07:17 AM
2+2GT's Avatar
2+2GT
Originally Posted by scottybaccus
Mustang (2 piston) 1.63"; total piston area 2.08"
Where do you see a 2-piston 66 Mustang caliper?
The area of each piston in a 65-67 Mustang Kelsey/Hays caliper is 2.07" (OK, 2.073942025221387") which yields just shy of 8.3" in each caliper.
Old Sep 19, 2011 | 01:08 PM
scottybaccus's Avatar
scottybaccus
Cool! I had no idea. I just looked up a general performance replacement on Rock Auto. I didn't dig for the fancy stuff.
What do those cost? Looks like about $100 each, so kinda pricey against the GM calipers at $15 each.
The only downside I see with them is the lighter weight rotor. The extra mass in the late model parts would be better for heat dissipation and fade resistance, but these would be a huge improvement over drums.
Old Sep 19, 2011 | 01:57 PM
2+2GT's Avatar
2+2GT
More like $120, since you'd have to eat the core charge. It was an off-the-shelf performance item. The Corvette had 4-piston calipers at the time, and actually used the same master cylinder and proportioning valve as the Mustang. In 68, Ford changed to a single piston caliper, probably because they were cheaper.
Old Sep 20, 2011 | 07:14 AM
andrewmp6's Avatar
andrewmp6
Chockostang has a kit for 68/69 with the stock k/h 4 pistons http://www.chockostangclassicmustang...nversions.html
Old Sep 20, 2011 | 08:56 AM
2+2GT's Avatar
2+2GT
Sure, I've used the K/H type 4-piston brakes on later Mustangs. Easier to install, and better brakes.
Old Sep 20, 2011 | 10:48 AM
chris66dad's Avatar
chris66dad
I have the CSRP Kit and it installed easy. The 4 piston Kelsey Hayes kit with everything you need is $524. http://www.discbrakeswap.com/
I also would also say to stay away from the Granada junkyard route. It was the only option for a long time to get disk brakes on Mustangs but there are now many vendors selling high quality kits. You will save frustration, time and money with a kit
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
