Hosing off enigne?
Old Sep 7, 2005 | 07:19 PM
tylerdru's Avatar
tylerdru
Default Hosing off enigne?
Can spray my enigne down if i cover the distributer and carb with a garbage bag. when the radiator blew antifreeze got everywhere. Whenever i start it you could smell burning antifreeze. [:'(]
Old Sep 7, 2005 | 07:31 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Hosing off enigne?
Yeah, just take your car to a wand pressure spray car wash and hose it down. Cover the distributor with plastic wrap. If you wish to take off the air cleaner housing as well, then cover the venturi of the carb with plastic wrap as well. While you are at it, you may as well spray some de-greaser on the engine to get rid of the oil leaks and dirt that has accumulated. If it won't start after you do that, then wipe out the inside of the distributor with a dry cloth.
Old Sep 7, 2005 | 07:48 PM
tylerdru's Avatar
tylerdru
ok sounds good. i figured i could do just that.
Old Sep 7, 2005 | 07:56 PM
Soaring's Avatar
Soaring
I ♥ Acer
If it studders a bit after you get her started, don't worry about it. It is just moisture that has accumulated, and will dry out after the engine warms up.
Old Sep 7, 2005 | 11:05 PM
tylerdru's Avatar
tylerdru
i will do this once i get all of my cooling system installed. I love doing all this car work! I could never imagine owning something newer just. If i did then i would miss out on a lot.
fastbackford351
Convertible Tech
Sep 27, 2015 06:51 AM
lmurf60
Sep 24, 2015 10:07 PM
Demodulates
Sep 18, 2015 11:14 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
