Cutting springs Wrong ?
Old Oct 9, 2011 | 08:05 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Since the top of the spring can be rotated and seated in any position it is not critical how much you cut off the spring. What is critical is how you reassemble the spring, upper A arm and the perch. If, when assembling, while you are loading the spring you see that the springs is not seated properly in the perch you need to unload it and rotate the spring so it will be up against the stop on the perch. How much you cut off the spring is only critical to the ride height not for how it fits into the stop on the perch.
69mach the tangental end is the bottom of the spring. If you cut the top the spring will be unusable. Use a cut off wheel to cut the springs.
Old Oct 10, 2011 | 10:37 AM
69mach1377's Avatar
69mach1377
That's what I thought, but did not recall that term being used before. So it is pretty simple after all.
Old Oct 10, 2011 | 12:07 PM
67t5ponycoupe
I had never heard that term either.
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mungodrums
Sep 28, 2015 10:54 PM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
