351w heads
Old Jan 16, 2012 | 01:33 PM
oxfordbp's Avatar
oxfordbp
Default 351w heads
I found a set of 351w heads for 50 bucks. They are "T" cast heads from 94. The valve size is 1.78/1.46. Will this be a good enough upgrade over my stock 289 heads? Are the springs heavier than stock 289?
Of course I would shave the head for proper compression.
Old Jan 16, 2012 | 01:46 PM
jojobanks's Avatar
jojobanks
not sure on the specifics of the 94 351w head, but I would mount it on the engine and do a valve clearance check using putty/clay before you shave the head too much.
Old Jan 17, 2012 | 10:27 PM
frdnut's Avatar
frdnut
They are not an "upgrade" over stock 289 heads at all...Especially if your 289 heads are pre 1968s...In fact you will lose alot of compression and gain nothing else..
Old Jan 17, 2012 | 10:36 PM
oxfordbp's Avatar
oxfordbp
yup, not getting them.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
guitarman376
Sep 30, 2015 05:54 PM
Drastang
Sep 30, 2015 03:48 AM
