PCV Valves ????
Old Jan 21, 2012 | 06:12 PM
Xring01's Avatar
Xring01
Default PCV Valves ????
I have a quick question...
Basically my motor is a roller cam 302, with Holley 600, built to 1985 GT Mustang specs...
Do I need to have a PCV Valve? What are the Pro's / Con's?
Thanks,
Old Jan 21, 2012 | 07:01 PM
2+2GT's Avatar
2+2GT
Well, if you don't use a PCV, oxides and sludge will build up faster inside the engine, and of course the vapor still has to come out somewhere, so the oily vapor will deposit itself on the outside of the engine, making a mess. Your choice.
Old Jan 23, 2012 | 04:07 AM
kalli's Avatar
kalli
ya, you'll end up with a lot of mess around the breathers etc. I wouldn't run an engine long term without it (means eventually I'd always add a PCV)
Old Jan 24, 2012 | 01:26 AM
Boxwrenchesareslow's Avatar
Boxwrenchesareslow
another Run PCV Valve vote here
Old Jan 24, 2012 | 04:00 AM
jojobanks's Avatar
jojobanks
one thing I have thought about doing is making an oil catch can for the pcv system. That way all the gunk still gets sucked out, but it doesn't go into the intake and make a mess of it.
Old Jan 24, 2012 | 05:05 AM
kalli's Avatar
kalli
i can show you my intake. no mess there. it's washed down and burnt.
Its only when it comes out of the breathers it deposits itself on the rocker covers and stays there
Old Jan 24, 2012 | 05:34 AM
jojobanks's Avatar
jojobanks
mine isn't too bad either, but I do get a little bit of buildup in the runners. I just think a catch-can setup would look cool
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
