Junkyard T5's
Old Jan 28, 2012 | 09:05 PM
oxfordbp's Avatar
oxfordbp
Buy it cheap and rebuild it. Still cheaper than new.
You could try shifting it, pay close attention to third gear.
Old Jan 30, 2012 | 01:12 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Google search T5 transmission id and do some reading before going out to the junk yard. Here are some links to get you started. http://www.5speeds.com/t5/ http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm The fast way to tell a non-WC from a WC is to tip it up on end and if 90 weight gear oil comes out it is a non-WC. If ATF comes out it is a WC. Also look a the front bearing retainer there is a difference between the WC and non-WC that is expained in the first link I posted. The ID tag is usually missing from the these transmissions whick makes ID a lot harder. The tag should be on a tail shaft bolt.
Old Jan 30, 2012 | 01:26 PM
jojobanks's Avatar
jojobanks
actually more times than not you'll find gear oil coming out of it regardless if it's WC or not. They haven't made dextron II for years so the manufacturer recommends you use 50w gear oil instead if you change it.
Old Jan 30, 2012 | 03:40 PM
1971mach1's Avatar
1971mach1
My 4 cyl Turbo Coupe (1983) had a t-5 with ATF in it. I doubt that was a WC.
Old Jan 31, 2012 | 12:06 AM
Iskwezm's Avatar
Iskwezm
People are too stuck on a "world class" t5.The fact is they break just as easy.I had a WC on my n/a that broke 3rd driving normal.My 85 trans has been in my car for close to 7 years with over 525 ft lbs thought it and still shifts great.I dont know one of my friends or in my clubs that hasnt broken a t5 at some point.
ThatJuanStang
Sep 25, 2015 08:01 AM
67LimeCoupe
Sep 21, 2015 06:34 PM
vipergtrdj
Aug 25, 2005 10:41 AM
mkspeed26
North East
Apr 17, 2005 11:32 PM
Epd711
North East
Jan 25, 2005 11:32 PM
