Alternator question...
Old Feb 16, 2012 | 10:21 PM
1slow67's Avatar
1slow67
ROTM Moderator
Yeah that is my old one I had on my I6, I don't have any pictures of my newer one.
Old Feb 16, 2012 | 10:25 PM
Gun Jam's Avatar
Gun Jam
The single post all by its self opposite the side of the 3 others wires (on top in picture above) is the stator post.. Its 100% possible that its not utilized in your system. mine is not used either neither is BA's and that's as far as i know normal and fine.
-Gun
Old Feb 16, 2012 | 10:28 PM
oxfordbp's Avatar
oxfordbp
-Gun
Damn I was hoping it was that easy! ha..
Ill get some shots up tomorrow.
Old Feb 17, 2012 | 04:54 PM
oxfordbp's Avatar
oxfordbp
Problem solved! It was the Voltage Regulator! At first it showed 14.1v running then after a few minutes it settled at 13.2v. So i will just buy another one and replace it!
Why are there 4 pins on the regulator, and only 3 spade fittings on the plug? I think its the Field that is not there?
Old Feb 18, 2012 | 12:04 AM
Gun Jam's Avatar
Gun Jam
field better be there. Its probaly the top one thats blank... (I) Ignition I think. It would be used to run a charge indicator light if your car was so equipped.
-Gun
Old Feb 18, 2012 | 01:21 AM
oxfordbp's Avatar
oxfordbp
-Gun
I could be wrong, Ill check tomorrow.
Old Feb 18, 2012 | 09:40 AM
JMD's Avatar
JMD
Depending on the age and condition of your battery, you could have 12V at the battery and a properly functioning charging system.
A weak battery might absorb a portion of the current your alternator produces, but to no benefit or increase in voltage.
Judging by your voltage reading of 14.2 Volts at first, and 13.2 V after running, I don't think your regulator will be bad unless you are experiencing other symptoms.
I would be more suspect of poor cables/wires/terminals/connections than of the regulator.
Without reading the article, so what I say may or may not apply here, but SOME tech articles are informative and helpful, and at the same time they might needlessly cause us to chase our own tail....
4cylinderplus2
Oct 9, 2020 07:45 PM
Golfsito
Oct 6, 2015 11:02 AM
MasterLanMan
Sep 26, 2015 10:03 AM
Wombatnation
Sep 13, 2015 09:16 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
