spongy pedal
Old Feb 21, 2012 | 03:32 PM
slick66stang's Avatar
slick66stang
Default spongy pedal
got my whole brake system redone new lines master cyl the whole nine yards now my brakes are spongy only when the car is running i have manuel drum brakes and ive bled all the air out and dont know whats causing this any help
Old Feb 21, 2012 | 03:51 PM
Gun Jam's Avatar
Gun Jam
only when the car is running? what do you mean by running, revved up, idle, rolling, ????
if its manual drum there should be ZERO interaction between an idling engine and the brakes.. or a revved up engine and the brakes.
-Gun
Old Feb 21, 2012 | 06:43 PM
boogerschnot's Avatar
boogerschnot
Sounds like more air in the system. Or if you changed your master cylinder maybe it wasnt bench bled correctly.
Old Feb 21, 2012 | 10:00 PM
musnicki's Avatar
musnicki
Bleed out the farthest brake first, the rear right and work your way to the closest brake.
Also, check to see if your brake pads are installed correctly. I did my brake lines a while ago and go brake fluid all over my hands for a few hours while bleeding which mildly burned my skin. The short of it is, I took it to Midas (brake experts right?) to get all of my rotors grinded because it was braking eratically. While they were grinding the rotors, they asked me about new pads, so I had them put in thinking about my burnt hands. Well, they put the back ones in wrong. My pedal was spongy and I didn't notice until I got home. I live up near a mountain, uphill from the almost beach location of the Midas store.
James
Thunderball
15
Nov 22, 2015 11:49 PM
piotrek53
Oct 13, 2015 06:54 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
col2560
Sep 25, 2015 06:51 AM
ccdguy
Sep 19, 2015 05:20 PM
