Rear end question
Have a 71 Mustang, pictured below, and I was wondering what the best(cheapest haha) donor car is for an 8.8 or 9 inch rear? I am looking at the Currie rear on Jegs right now, but I REALLY don't want to pay $1,300 before taxes/shipping/gears/brakes/etc.
Any ideas?
Any ideas?
Are you trying to make more then 400 hp?? if you're not then i would just stick with the 8" its a bit lighter and can hold up quite well.
But if you want a 9" then
1967-1973 medium and big block Mustangs and Cougars
1966-1971 Fairlanes, Torinos, Montegos, Comets, and other Ford intermediates with big blocks.
1957-1959 V8 Fords and Mercurys
1977-1981 Lincoln Versailles & Trucks
this came from here http://dfwmotorsport.com/Fairlane/9inchrearends.htm
just look around on craigslist for rearends, even if the width is too big you can always have the housing cut and respline the axles. the extra brackets (if there are any) would also need to be cut off and spring perches welded on. it sounds like a lot of work but it will still be cheaper than the new curry or jegs ones
If I am not mistaken, a 67 - 73 mustang 9" will fit your car. there is a guy (Mike's Mustang shop) in Maryland that will sell you the 9" housing and axles for $450 and I think $750 if you include the third member. I picked one up from him in December and he had about 20 more in a pile in his junk yard.
Per Xarong, I've seen cars running 600 - 700 hp with a 8". If you don't plan on putting slicks and drag racing every weekend, keep the 8". You might want to get better axles and a better third member if you plan on making more than 400 hp.
The junk yard (Mustang resting yard) is called Mike's Mustangs. He used to have a web site, but I think he has taken it down. He is still open for business though. Call before you go. :Ask for Mike Hedges. 2800 Camp Hedges Pl, Bryans Road, MD. 301-283-0344
You might also want to check with CJ Pony Parts and see if the can recommend any places in PA that you could go to.
With your plan, going the 9" is the best way to go, but look at spending slightly over $2k for everything to handle that kind of horsepower.
On the rear end sizes it went 64-66 67-70 and 71-73.You can get a used housing and axles for about 350 bucks http://www.perogie.com/Rears.htm or new http://www.quickperformance.com/Products/housings.htm but look around on quick performance website they are cheap and good.
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
92 5.0stang
Aug 13, 2015 06:46 AM
