change over from four lug to five
Old 05-10-2013, 08:34 PM
my68
my68's Avatar
Default change over from four lug to five
i have a 68 coupe six cyclind i have owned it since 1995 , i have put air , power steering and a few other up grades, i want to change the four lug over to five lug, i have been told the rear axle switch is simplejust pull out the four lug and reinstall 5 lug sounds to simple is this correct, the other question is changing over the front any help would be appreciated thanks again
my68 is offline
Old 05-10-2013, 09:26 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yeah for the rear you will need an 8inch or 9 inch rear axle with 5 lugs and the correct spacing for the spring perches and axle length..
as for the front you will need new spindles setup for 5 lug, all new steering linkage brake lines etc etc
rmodel65 is offline
Old 05-11-2013, 05:14 AM
Al Newman
Al Newman's Avatar
You can probably order a set of 5 lug 25 spline axles from someone, but I've not seen that done. Most changeovers are done with the entire 8" or 9" axle assembly from a V8
As for the front hubs, the 5 lug V8 hubs and backing plates will fit onto your existing spindle. Additionally, you will have to change all backing plates and brake assemblies to the 10" V8 stuff, as I don't think you can get 9" 5 lug drums.
Best,
Al
Al Newman is offline
Old 05-11-2013, 11:57 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
the 5 lug back plates and brakes will not fit on a sixxer spindle...i think you are confusing disc brakes swapping over to drum v8 spindles AL
rmodel65 is offline
Old 05-11-2013, 11:58 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
honestly id go this route http://discbrakeswap.com/ buy the disc brake kit complete with v8 spindles and then you just need the steering stuff to do the swap up front..
rmodel65 is offline
Old 05-11-2013, 05:53 PM
2+2GT
2+2GT's Avatar
Originally Posted by my68
i have been told the rear axle switch is simplejust pull out the four lug and reinstall 5 lug sounds to simple is this correct?
No, no such axles exist.
Why do you want to do this?
2+2GT is offline
Old 05-11-2013, 06:21 PM
chockostang
chockostang's Avatar
I my be reading this totally wrong on the front brake advice?
The facts are, there is no difference in 6 cylinder, and V8 Drum front spindles. ALL/EVERY 6 cylinder, and V8 Drum brake cars in 67 68 69 received the same spindles on the production line, it was the dress that was different.
6 Cylinder received small backing plates, smaller shoes, smaller cylinders, and of course 4 bolt/smaller drum, V8 cars received the 10", 5 bolt pieces.
To change a 67 68 69 Drum Brake car to 5 Bolt, simply strip the spindle of the 6 cylinder pieces, bolt on the V8 pieces.
Now Disc Brakes. To put the 67 4 Piston per caliper K/H Front Disc brakes on these 67 68 69 Drum Brake Equipt cars-spindles, Strip the spindle, BOLT ON the K/H 4 Piston Disc Brakes as all 67 Mustangs, Shelbys had.
Dan @ Chockostang
chockostang is offline
Old 05-11-2013, 06:22 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
ohhh youre right Choko i didnt notice the 68 part
rmodel65 is offline
Old 05-11-2013, 06:26 PM
chockostang
Believe me I can misread more times than I care to think about!
Thank You for your imput on these Forums
Dan
Old 05-11-2013, 10:09 PM
120mm
120mm's Avatar
You need to get an entire rear end assembly, hopefully from another Mustang or Cougar, 1967 to 1970, due to the spring perch and overall width.
What I did was to find someone who was asking questions about going to a 9" rearend and buying their 8" after they made the leap.
120mm is offline
flash_xx
10-16-2015 07:23 AM
Dathan
10-05-2015 05:52 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: change over from four lug to five
