Rough idle when in gear (automatic), etc
Old 12-16-2013, 06:44 PM
barnett468
barnett468's Avatar
hi,
yes thats a lot of play but if you spray flammable brake cleaner at it gently using the long nozzle i mentioned and your rpm does not increase it is not the source of your prob guaranteed.
that is a 70 carb.
barnett468 is offline
Old 12-22-2013, 12:00 AM
cantorhome
cantorhome's Avatar
Here's the latest:
The car is running now, but only with the chock engaged. Even after he motor is nice and warm, I can't back the choke off or the engine dies. Because of that, the idle is quite high (maybe 2K RPM), and I can't lower it with the idle screw.
The timing is correct, at 10 degrees. The fuel mix is where it was before the engine suddenly started having this problem, and changing the fuel mix screw doesn't seem to affect the motor at all, until I get it screwed in, within about two rotations from its lean limit.
I took the carb apart again, and nothing seems amiss.
cantorhome is offline
Old 12-30-2013, 11:51 PM
boogerschnot
boogerschnot's Avatar
Hmmm.. cantorhome, where are you located in Ca? I'm down in San Diego.. maybe I could help you out sometime. PM me.
boogerschnot is offline
Old 12-31-2013, 04:36 PM
barnett468
barnett468's Avatar
hi,
ok, if you sprayed clraner at the loose throttle and you have no air leaks then your idle circuit is likely plugged up.
Take flammable brake cleaner or carb cleaner with the long nozzle.
remove the fuel mix screw.
spray in screw hole for 5 seconds.
find the tiny holes in the carb throat and push the nozzle against them and spray for 2 - 3 seconds.
try eng again.
if it still stalls check the float level height and power valve for debris.
mtgldr
02-03-2024 09:00 PM
2007StangV6
01-28-2016 06:09 PM
musnicki
09-23-2015 07:11 AM
nboost
09-16-2015 05:35 AM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
Quick Reply: Rough idle when in gear (automatic), etc
