1969 power steering problem
Old May 25, 2014 | 09:33 PM
mcaputo's Avatar
mcaputo
Default 1969 power steering problem
Hi im new here but i have a 69 two door coupe and i have had alot of problems with my power steering control valve i have fixed all of the leaks that have occurred in the system replaced half the lines and rebuilt the original control valve I am to the point where I have no pull at all in the steering (it was pulling severely to the right) i adjusted the lock nut behind the cover with two bolts at the end of the control valve it is nearly all the way lose and has blown two o rings in the small hole in the lower left corner i replaced it with a bigger o ring but i still have no power steering to the left we bled the system wile the front tires were off the ground and the steering seemed great untill the wheels were on the ground again i am out of ideas
(also the control valve has only about 20-25 threads showing where it attaches) and I also need a new power steering pump sorry for such a long post
Old May 26, 2014 | 06:16 AM
2+2GT's Avatar
2+2GT
There should be no O-rings in the control valve.
If the pump is shot, you won't get any satisfaction from the steering gear.
Old May 26, 2014 | 07:14 AM
chockostang's Avatar
chockostang
You have 20-25 threads showing where the control valve screws on the centerlink/????
If this is the case, the control is not installed correctly. on average there will be 3 or so threads showing.
You cannot have installed the roll pin if the control is that far off center--remember to roll pin it, then clamp it.
The O ring thing. To change the O rings in the reaction valve plugs, you have to remove the plug, put on new O rings, then push back in. They do not go on the outside under plate.
If you have the nut under the cap more than one turn out from where it stopped, it is wrong, will not work.
Dan @ Chockostang
Old May 27, 2014 | 07:13 AM
69mach1377's Avatar
69mach1377
I've got a manual conversion kit if/when you are ready...
Cit95
Sep 22, 2015 07:08 AM
S'PortMustang69
Aug 30, 2015 08:27 PM
kdryan
Aug 29, 2015 09:57 PM
Tyoung68
Aug 25, 2015 04:31 AM
clevelandcat
Aug 24, 2015 01:18 PM
