Gauge woes
Old Jun 23, 2014 | 03:57 PM
TexasAxMan's Avatar
TexasAxMan
Default Gauge woes
I went for a good long drive Saturday and everything went smoothly except my temperature gauge was reading very high. I stopped to check it out and the thermometer on the radiator cap (Mr. Gasket) was only showing 200*, no hissing, no boilover ... So I must have the wrong sending unit. What should the resistance be at say 85* and also at 200*?
Also, I thought I was almost out of gas. I stopped to fill it up (a chore in itself) and after 5 gallons it was to the bottom of the filler neck. The gauge read right at half a tank. So that sending unit must be the wrong one too. So again, what should the resistance be at empty and also at full?
Any help appreciated!
Old Jun 23, 2014 | 04:08 PM
Gun Jam's Avatar
Gun Jam
what makes you think the sending units are bad?
These gauges never worked right? If they did when did they last work right?
Old Jun 23, 2014 | 05:54 PM
barnett468's Avatar
barnett468
hi;
if your water sending unit is not orig and it has always done this most likely it is incorrect, you are best off buying a used orig.
the tank sender float might just need adjisting it is ariund 10 ohms full and 90 empty.
Old Jun 23, 2014 | 07:05 PM
TexasAxMan's Avatar
TexasAxMan
Thanks barnett468, that's what I was looking for on the fuel gauge.
Anyone know what the specs are for the temp sender?
Old Jun 23, 2014 | 08:00 PM
barnett468's Avatar
barnett468
10 ohms in sender = cold on gauge
25 ohms = middle of gauge
80 = hot on gauge
try a standard motor part TS 58 and TS24 if yours is bad.
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
