68 Stang Ball Joint PLUGS???
Old 08-25-2015, 04:45 PM
unit91
unit91's Avatar
Default 68 Stang Ball Joint PLUGS???
Was lubing the Stang and checked my Chilton book to make sure I didn't miss anything. I noticed the book said you have to remove the ball joint "plugs" in order to lube the upper and lower ball joints. I've googled the term ball joint plug and can't find a photo or any information. Anyone got a photo of a ball joint with a plug in it? Did Ford replace the plugs with zerks? Mine have zerks.
unit91 is offline
Old 08-26-2015, 02:37 PM
67LimeCoupe
67LimeCoupe's Avatar
IIRC they did come with plugs but most were switched over to zerks at one point for serviceability.
67LimeCoupe is offline
Old 08-27-2015, 03:41 PM
unit91
unit91's Avatar
Makes sense. Thank you.
unit91 is offline
Old 08-31-2015, 08:30 AM
bop11
bop11's Avatar
It was an advertising gimmick. Lubed for Life, or Lifetime Lube or something like that. I remember we all laughed back then and pulled the plugs which were just little bolts and put in the zerks. I think the dealers pulled them put in zerks , lube then replaced the bolts and charged for this at the 50,000 mile service and called it a standard. Almost every make did it.
There are special right angle zerks for the upper A-Arms.
bop11 is offline
Old 08-31-2015, 10:27 AM
unit91
unit91's Avatar
Interesting. Thanks for the info.
unit91 is offline
BOB ROME
07-26-2023 01:54 PM
Bokeo
10-10-2015 08:28 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
marc954
09-29-2015 11:18 AM
Quick Reply: 68 Stang Ball Joint PLUGS???
