Pinion Angle Clarification
Old Dec 11, 2015 | 09:24 PM
  #21
barnett468's Avatar
barnett468
you have a bit of a cluster **** . . you need to raise the back of your trans before you do anything or it will still be a cluster ****.
the trans should be 3.5 degrees.
raising the pinion will increase the angle of the driveshaft to the trans which will increase the amount of cluster **** and vibration it probably already has . . this angle should be no more than around 3 degrees with the car in a static position and it is already at 3 degrees.
if you do not raise the trans, you are probably wasting your time, it's that simple.
if you leave the trans where it is, i would put a 4 degree wedge in the rear to bring the pinion up to 5 degrees and then pray.
Old Dec 12, 2015 | 01:48 AM
  #22
guitarman376's Avatar
guitarman376
That is good information to know. Is there an easy way of measuring the transmission angle? I am not 100% sure my method was the best, but the yold/DS u joint wouldn't come apart (and after realizing there are rollers in the caps I'm kinda glad). I guess I will start with shimming the transmission up as much as I can and retake measurements.
Old Dec 12, 2015 | 01:51 PM
  #23
barnett468's Avatar
barnett468
well, if your trans and trans mount are stock, it should be 3.5 degrees . . if you have a t5 trans, is will be slightly more, if you have a tko trans, it will be even more.
if you have a stock intake manifold, you can remove the carb and check it on the carb pad, otherwise yes, it is a pita to do and must be done underneath . . you can pull the driveshaft and use the end of the trans but that's also a pita.
Old Dec 13, 2015 | 12:55 AM
  #24
guitarman376
Yea I thought about doing that, but the tailhousing seal looked like it protrudes too much to set an angle finder on the transmission. I also assumed I would lose all my atf, still running stock fmx. So the carb flange on the stock manifolds are directly level with the driveline? I might remove the carb and do it that way.
Old Dec 13, 2015 | 09:13 AM
  #25
69mach1377's Avatar
69mach1377
Some tail seals also have a dust boot that is not really required unless you do a lot of dirt roads.
mtgldr
Feb 3, 2024 09:00 PM
fcarpio
Suspension
Nov 16, 2018 10:35 AM
mustang0291
Oct 12, 2015 07:55 AM
tmdm
Sep 18, 2015 03:10 PM
97SN95GT
Sep 13, 2015 09:45 PM
