Heater core mod help
Old May 11, 2018 | 04:31 PM
  #21
Worth1's Avatar
Worth1
Originally Posted by Eddievalleytrailer
The valve will reduce the flow rate, but will do nothing to reduce the pressure. The ONLY thing that controls pressure in the system is the simplest thing to replace...the radiator cap. They can cause all kinds of problems, yet for some reason, people are reluctant to replace them. They are cheap and easy to replace.
He's not talking about system pressure, the issue he feels he has is a pressure build up in the core from high velocity coolant flow. And if that is true then the flow restrictor will reduce the pressure in the core.
Old May 11, 2018 | 09:13 PM
  #22
barnett468's Avatar
barnett468
Originally Posted by Gun Jam
If I restrict water flow from the intlet line this is going to reduce pressure to the core correct?
It will reduce pressure caused by water pump but will not affect the atmospheric pressure in the system.
Old May 11, 2018 | 09:43 PM
  #23
barnett468's Avatar
barnett468
Can you link me to a heater core that is NOT crap?
Exactly which cores have you used so far?
Old May 12, 2018 | 12:01 AM
  #24
Gun Jam's Avatar
Gun Jam
Both the Aluminum and Cu/Brass from oreally? auto parts
The Scott drake one, the CJ Pony parts one (which I think are both Norther brand) and One from NPD.
Old May 12, 2018 | 05:03 AM
  #25
Worth1's Avatar
Worth1
One other thing I didn't think of before, you can run a bypass hose between the 2 heater hoses by installing a "T" or "Y" fitting in each hose. This will allow the fluid to go the path of least resistance. It should allow full flow threw the heater at low rpm, and if the pressure increases in the core the fluid will take the bypass.
Old May 12, 2018 | 09:24 AM
  #26
Gun Jam's Avatar
Gun Jam
so far the valve has been working well. i didn't want t run the T because I couldn't find a clean spot to install it.
Old May 12, 2018 | 10:58 AM
  #27
barnett468's Avatar
barnett468
ok, the only other option i am awate of then is a custom one. two places you can get them from is flowkooler and brassworks but they are around $225.00
drake used to have a good one i might have mentioned to you a while back but they no longer carry it.
Old May 12, 2018 | 04:58 PM
  #28
Gun Jam's Avatar
Gun Jam
Nice thanks for the tip...ive got no issue paying 225 for one if it holds up. Ill go that route if the valve doesn't pan out.
joshsblazer93
Dec 22, 2009 01:06 AM
urban_cowboy
Jul 4, 2007 12:14 AM
LesteR723
Jan 1, 2007 06:34 PM
gtboy2k
Nov 6, 2006 05:13 PM
Machwon
May 20, 2006 02:10 PM
