1966 Mustang 3-Speed, 200 ci 6 manual transmission and rear axle fluid.
Old 11-12-2018, 08:25 AM
elh130
elh130's Avatar
Default 1966 Mustang 3-Speed, 200 ci 6 manual transmission and rear axle fluid.
Ladies and Gents-
New Mustang owner with fluid replacement question. I need to add fluid to both my manual 3-speed transmission as well as my rear axle. The shop manual calls for the following fluid which are no longer available:
Transmission: C3RZ-19C547-B (Rotunda Manual Transmission Lube)
Rear Axle: C1AZ-19580-E or F (FoMoCo Hypoid Gear Lube)
What should I be using and when can I find the appropriate fluids? I've search around and there is a lot of conflicting info. Thanks all!
Erik
elh130 is offline
Old 11-13-2018, 03:48 AM
1slow67
ROTM Moderator
1slow67's Avatar
From what I've seen they recommend a GL-4 gear oil for the older transmissions like your 3 speed and a GL-5 oil for the rear end.
1slow67 is offline
07vbluestang
04-30-2010 07:32 AM
countrystang
07-31-2009 10:30 PM
Blacksmoke
09-06-2007 12:02 PM
Erdrickk
08-04-2007 08:13 PM
tdappleman
09-08-2006 02:06 PM
Quick Reply: 1966 Mustang 3-Speed, 200 ci 6 manual transmission and rear axle fluid.
