radiator for a/c upgrade
Hello
I have a 1965 mustang (289, 4 speed) in which I will soon be replacing the radiator; it currently has the original mustang radiator in it but before I replace it with a new identical one------ this concern:
Down the road, I hope to install an air conditioner in the car and was wondering if the standard type radiator will be adequate to cool the motor with an a/c or should i replace it with something different -- thoughts and suggestions appreciated
if your engine is not bored out more than .030" and you have stock compression, a high efficiency 3 row rad from us radiators (coolcraft.com in arizona) with a stock fan shroud will work fine, and a good water pump like a flow klooler and brass milodon 180 degree t stat will also help.
