Engine Compression Results - 260 V8 1964 1/2
Old Dec 31, 2020 | 06:07 PM
timnoles's Avatar
timnoles
Default Engine Compression Results - 260 V8 1964 1/2
I just did a dry/wet compression test on the car and don't really know what to make of the results. The car is a 1964 1/2 Mustang with a 260 V8 and about 98K Miles. It hasn't been driven much at all since 1985, but I believe the previous owner had a mechanic that would start the car occasionally and do routine maintenance. I don't know if it has had any work done to the engine like a valve job or anything within the block.
Cylinder Wet Dry
1 127 120
2 130 130
3 125 125
4 125 120
5 135 132
6 145 125
7 125 120
8 130 125
All seemed to be within 10 PSI of one another except Cylinder 6 on the wet test. I may have added a little more oil in that one so maybe that was the reason for the higher reading.
Do these seem to be within spec for a car that is 55 years old with almost 100,000 miles? Is there anything here that might lead you to believe something is wrong?
Thanks in advance.
Old Jan 1, 2021 | 09:22 PM
Gun Jam's Avatar
Gun Jam
No this looks good to me. With compression values of that number and std deviation I would expect no trouble from this engine cylinder or piston wise.
Old Jan 2, 2021 | 07:34 AM
timnoles's Avatar
timnoles
Thanks for the reply on both of my posts. I appreciate the information. 👍🏻
Jason Moussalli
Mar 6, 2016 03:33 PM
Dean Paradise
May 2, 2013 08:58 AM
lexy
Feb 26, 2008 11:52 AM
86GT 93LX
Oct 12, 2007 09:19 AM
Foxbodyforever
Jun 12, 2007 10:21 PM
