Need help
Old Jul 19, 2021 | 01:59 PM
Kevinmf's Avatar
Kevinmf
Default Need help
Im working on a 1966 mustang strait 6 it was over heating so we replaced thermostat and water pump i filled the radiator started it up it and it got warm could not see the coolent moving in radiator reved the motor up as soon as i let off the gas coolent pured out the top of radiator and still wants to over heat any ideas im thinking head gasket but not for sure
Old Jul 20, 2021 | 06:18 PM
Gun Jam's Avatar
Gun Jam
when did it start doing this and how hot did you get it when it first started over heating?
Old Jul 20, 2021 | 09:55 PM
Kevinmf's Avatar
Kevinmf
So a friend wanted me to do a tune up and get it running better so he could put it in a parade it was running like sh*^ as i get started i notice the air filter was up side down i pulled the plugs they were so black and the build up on them im amazed it ran at all changed tthem and wires fuel filter pulled some gas out the tank was really cloudy and grose draind it got fresh gas in it it ran way better radiator fluid didnt look good but not really bad he drove it a few hrs the next day then went a couple miles in the parade it stared running worse few minutes later steam and coolent all over under the hood he got some water in it after a bit got it home thats when i did the thermostat and water pump like i was talking about in the first post
Old Jul 22, 2021 | 05:58 PM
Gun Jam's Avatar
Gun Jam
does the engine oil have any water in it? Are you able to observe any coolant on spark plugs or inside the combustion chamber?
It likely either has a plugged up radiator that isn't flowing well or a blown head gasket secondary to a plugged up radiator.
Does it ever act hard to crank over like the battery is low on first starts? Does a bunch of white smoke come out when it does start?
Old Jul 22, 2021 | 09:48 PM
Kevinmf's Avatar
Kevinmf
So i swaped out the radiator and it seen to be working good any ideas on so i did the tune up plugs fouled bad some were dam near soled chunk and it leaves a black mark under muffler every time you rev it up how to blow all that **** out
Mustang1994
Jun 27, 2012 02:40 PM
brian1570
18
Feb 18, 2009 09:55 PM
Vikefan88
May 1, 2008 03:15 PM
robert912004
Jun 27, 2007 03:09 AM
67_FASTBACK
Aug 27, 2005 07:37 AM
