289 camshaft advice needed
Old Nov 21, 2005 | 04:33 PM
RFortuna's Avatar
RFortuna
Default 289 camshaft advice needed
Need some technical advice here. 65 fastback 289 C code, 131,000 miles. Mechanic replaced timing chain and gears. A few days later car stops running, not getting any fuel. Fuel pump eccentric has come loose frome the camshaft. We thought the mechanic forgot to tighten it. He went back in, put it back together, ran great for a few days, then same problem. Took it back apart and the same thing has happened. He now says that the camshaft has too much fore and aft movement, allowing the pin that holds the eccentric in place to back out. Wants to replace the cam and lifters. Could the camshaft have that much movement with out having other problems? I don't want to pay this guy to replace the cam and lifters only to find out that the motor needs to be torn down again for more serious repairs. Any advice would be appreciated.
Old Nov 21, 2005 | 05:38 PM
downwardspiral's Avatar
downwardspiral
Default RE: 289 camshaft advice needed
ORIGINAL: RFortuna
If the cam and lifters wore out, my guess is that other mechanical parts would be worn out too. Your going to have to change the cam anyway, so my advice would be to just take care out that for now, but watch for any problems in the engine. If anything else is going wrong, I would probably rebuild the engine, because everything is just going to break down the road.
Old Nov 21, 2005 | 08:49 PM
hutchamatic's Avatar
hutchamatic
NO. Loctite should be used and the bolt should be torqed. I have never had this problem. But a worn cam would not cause this at all.
Old Nov 23, 2005 | 12:01 AM
Silver Ponys's Avatar
Silver Ponys
I dont think the cam can move that much there is a keeper plate that bolts to the block to prevent this. I have seen the replacement cam dowels for the ecentric be too short. Hutch is right locktite everything.
Old Nov 23, 2005 | 03:43 PM
RFortuna's Avatar
RFortuna
Thanks Alot for all you help!
Randy
djbigskrilla
Sep 20, 2022 01:04 AM
Faolan65
Aug 27, 2015 06:40 AM
ding56
Aug 14, 2015 02:40 AM
defarmer
Aug 13, 2015 06:40 AM
Redneck1465
Aug 8, 2015 10:39 PM
